Announcements
Layer Manager Not Working Properly (Critical Situation)
omorah
omorah
AutoCAD 2023
Windows 10 Pro 64Bit
When I open the layer manager, which always opens, and apply a function, most of the time, whatever I set in the manager will NOT apply to the relating drawing. So, I had to create a CLASSICLAYER icon on my screen since about 80% of the time, that's what I use. The CLASSICLAYER is very time consuming dealing with lots of drawings, where I will have to always click the OK button after every function.
For me, I noticed the Layer Manager issue since AutoCAD 2018. I went through 2019 and 2023, and decided to upgrade to 2023 and still the same issue.
My co-worker (AutoCAD 2023) has similar issue with his Layer manager that when he click on the XREF tree, the list of XREFs in the drawing will not show, but will show the main Layer Manager tree at the top.
I have been Googling to find a similar solution.  I am desperate especially now that we are very busy at the office.
If you know of any post on this issue, please let me know.
Cheers
Replies (19)
paullimapa
type ABOUT and do a screen capture showing your 2023 version
if you can do a screencast showing when Layer manager fails would be best
Paul Li
IT Specialist
@The Office
omorah
paullimapa
 you do not have the latest updates installed on your AutoCAD 2023
latest should show:
Paul Li
IT Specialist
@The Office
omorah
I tried to recreate the Layer Manager's other issue on my computer, but seems the manager is temperamental.
LAYERMANAGER
It worked this time. However, most times, when I Freeze a layer in a Viewport, the manager will show it Frozen, but the property will NOT freeze in the Viewport.
CLASSICLAYER
When I freez a property in a view port, whenever I use the ClassicLayer, it WILL always work.
CO-WORKER'S COMPUTER (LAYER MANAGER)
In my co-worker's computer, most times, with an AutoCAD file opened, in the Layer Manager, when he selects the XREF section to freeze some layers in the Xref, the Xref folder will open the main folder instead, and will NOT list the Xrefs in that drawing.
omorah
Let me update and report back.
By the way, how do I reply to your post? Either "REPLY" or "QUICK REPLY" did not show my reply to your post. This forum does not have a means to quote someone. How's it done?
paullimapa
I'm using a web browser to see the entire thread which shows all previous messages.
But if you want to include a message from a previous reply, you'll have to do a copy & paste into your reply message like what I'm doing below:
omorah>>"Let me update and report back."
Paul Li
IT Specialist
@The Office
omorah
I also use a web browser (Firefox). I copied and pasted but it did not show like the attached image you from your "Message 2 of 7".  😫
paullimapa
Paul Li
IT Specialist
@The Office
omorah
@paullimapa wrote:
I think I got it. I missed using the quote icon in the header.
Thanks you so very much.
I downloaded the update, and it needed to restart my office PC since I am remoting from home. I will test it our later when I log back to the office. However, since my issue is temperamental, after update, after using it a few times, I will report back to let you know the outcome of the update. At the mean time. I just sent my co-worker a message to do an update to see if it will solve his Layer Manager issue. I will  also have to update my home installation of AutoCAD 2023.
I really appreciate your time in helping me on my AutoCAD issues. I will have to do a handful of tests on both my home and my office's (by remote connection) installations, before I would know if the update fixed it. The test might take me another day to do.
Thanks a bunch!!!!
Cheers
paullimapa
you may want to do all the tests on your home computer first after installing the updates, because the problem could also be caused by having a remote connection into your office computer.
Paul Li
IT Specialist
@The Office
omorah
Actually, it happens all the time when I am in the office.
pendean
Community Legend
Community Legend
@omorah trying to follow along, forgive me if I drift away from your topic (feel free to redirect me):
It looks like your LAYER palette belongs to another DWG file, not the one you have open. Perhaps your PC's restart will fix that?
Are you sure this happens at the office too?
Does it happen to all other users of 2023 in your office?
What method of connection are you using to remote in? As a quick test I took my laptop outside of our building to my car, did a quick RDP (then a VPN) connection to my desktop, and I cannot repeat your examples.
omorah
latest should show:
Till now, I have ONLY being using the LAYERMANAGER, have not used the CLASSICLAYER since installing the update 1.2. Thank you so much for your help.
paullimapa
Glad to be able to provide feedback....cheers!!!
Paul Li
IT Specialist
@The Office
omorah
Hello folks,
Am back again. This whole week my Layer Manager gets temperamental again, so I have to use the Classic Manager instead, most of the time. Please see attached video.
Cheers.
LayerManager.mp4
Video Player is loading.
Current Time 0:00
Duration 0:44
Loaded: 21.98%
Stream Type LIVE
Remaining Time 0:44
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    pendean
    Community Legend
    Community Legend
    @omorah Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
    https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
    omorah
    Ok, thanks.
    omorah
    I think when it happens, I'll reset AutoCAD to installation default. If it does not happen, I might suspect my configurations and my macros from years back.
    Same way, sometimes my cross hair and command window resorts to AutoCAD default, in which case, I have to once in a while change them.
    Thanks for all, I'll get help with the technicians.
    Raymarcher
    Same problem here, Civil 3D 2023.
    The issue appears once I go in viewport modus.
    Closing and reopening the layer manager solves the problem until I exit and enter viewport modus again.
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
