LAYER ISOLATE
LAYER ISOLATE
LAYER ISOLATE
how to select only one layer and turn off all others?
imadHabash
>> how to select only one layer and turn off all others? <<
LAYISO command . ( your post headline) 🙂  and check Settings via the command to specify how to behave . >> Click <<
Command: LAYISO
Current setting: Hide layers, Viewports=Off
Select objects on the layer(s) to be isolated or [Settings]:
regards,
Imad Habash
scot-65
In addition to Imad's suggestion,
If a viewport is set up with the correct layer state,
commands VPMAX and VPMIN will allow one to
"go inside" to do any editing. One is free to pan
and zoom without loosing the viewport scale and
position relative to the model space. No need to
lock the viewport for this suggested method.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
leeminardi
First suggestion, I recommend freezing a layer rather than turning it "off".  A frozen layer is more off than an "off" layer. For example, objects that exist on off layers will be selected when you respond "all" to the prompt "select objects" whereas objects on frozen layers will not be selected.
To freeze all layers except the current layer try:
-layer [Enter]
f [Enter]
* [Enter]
lee.minardi
so frozen layers can also be turned off? so i should first freeze and then turn off and otherwise i may select things on a layer or 200 layers that i do not even see?
leeminardi
Freezing a layer is sufficient. If a layer is frozen you do not need to turn it off.  Objects on a frozen layer cannot be seen or edited.
Check out the differences here
lee.minardi
