Layer - Cannot make current
bmcnally
Message 1 of 37
bmcnally
I'm having an issue where I try to select multiple objects (lines for example) and use the layer dropdown to put them on a different layer (that happens to be frozen). I get a message that says "The selected layer cannot be made current".  I don't understand because it's not like I'm trying to change the current layer.  I'm only trying to put selected objects on a layer..
By the way, if I only select one object (a single line), it works fine!  Very frustrating
Replies (36)
Message 2 of 37
pendean
Community Legend
Community Legend
It happens rarely but noticeably often with one or dozens of objects here too: your click is read as a request to make the layer active.
Are you saying to happens to you ALL the time, always, never ever a variation, an din all files not just this one? if yes, what if your AutoCAD version/variant and what is your Windows version.
Message 3 of 37
Ranjit_Singh
Check PICKFIRST. Set it to 1.
Message 4 of 37
pendean
Community Legend
Community Legend
PICKADD variable if it's multiple and not single objects.
Message 5 of 37
bmcnally
yes, happens all the time and between different files.
Message 6 of 37
bmcnally
pickfirst is set to 1 already.  Thanks
Message 7 of 37
bmcnally
PICKADD  was set to 2.  Tried to set it to 1 and the same thing happens.
Message 8 of 37
bmcnally
Using AutoCAD 2018
Message 9 of 37
Ranjit_Singh
@Anonymous wrote:
............ "The selected layer cannot be made current".  ........
That will only happen when AutoCAD looses the selectionset before changing the layer, as shown below.
You are certain that PICKFIRST is set to 1? What happens when you select entities and just move to a thawed layer? If they still do not move and simply change the current layer then somehow the selectionset is lost. Test on a different drawing or restart CAD. Try on different workstation. Sometimes the mouse may need updated drivers or even replacing the mouse itself.
Message 10 of 37
bmcnally
thanks for the video!  that message is exactly what I get except that I already have PICKFIRST set to 1.  i feel like you're close to a solution as you're able to replicate the issue.  I tried to restart AutoCAD and same thing happens.  Will try to restart my CPU now...
Message 11 of 37
Patchy
Did you use any ADD-ON app?
Message 12 of 37
Ranjit_Singh
What happens when you use the PROPERTIES window? It works for me even while PICKFIRST is set to 0.Moving_objects_2_frozen_layer_2.gif
Message 13 of 37
bmcnally
Weird. I'm able to select several lines at once and move them to a frozen layer via the properties window like normal. Just get the usual message that they're moved to a frozen layer. But for some reason, when I do the same thing but use the layer dropdown, it thinks I want to make the frozen layer current...
Message 14 of 37
pendean
Community Legend
Community Legend
Can you actually see your selections get deselected as shown in the video above?
What mouse and mouse driver are you using?
Message 15 of 37
Ranjit_Singh
That does not make sense. Based on what you have described so far, the selectionset is lost when using the layers panel but it is not lost when using the properties palette? You may want to post a screencast so members better understand the problem. Go here to upload a screencast.
Message 16 of 37
jlaidle1
I agree, upload a screencast with your steps.  I am not able to replicate your behavior.
John Laidler
ITO - Application Management
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 17 of 37
bmcnally
See if this works...
http://autode.sk/2yNbKw7
Message 18 of 37
bmcnally
Message 19 of 37
jlaidle1
Verify the below option is turned on.
John Laidler
Message 20 of 37
RobDraw
That is the PICKFIRST variable, which has already been verified.
Rob
