Does anyone have a lisp that will convert the layer manager setting for each layer from ACI to RGB?
I have found a few lisps that will convert entities / objects but I have not discovered one that makes the change at the layer manager level on a per layer basis.
Thanks in Advance
-Tim C.
Solved by vinodkl. Go to Solution.
See if this helps: https://lispbox.wordpress.com/2017/12/19/convert-selected-aci-color-layers-to-rgb-index/
