launch AutoCAD
OlgaGan
launch AutoCAD
OlgaGan
Hello Dear AutoCAD specialists!
Please tell me how to force launch AutoCAD without the "Tool Palettes Manager" open (*AutoCAD was closed with the "Tool Palettes Manager" open.)?
0 Me gusta
Responder
Soluciones aceptadas (1)
436 Vistas
5 Respuestas
Respuestas (5)
ChicagoLooper
@OlgaGan
If the Tool Palettes manager was open when you closed AutoCAD it’s OK. It doesn’t affect the program the next time you launch it.
There’s has to be something else that’s causing the failure to launch.
Would it be possible to describe what you were doing right before you shut down?  Be detailed. (You may leave out the part about the Tool Palette being open because that part is unimportant.)
Chicagolooper
0 Me gusta
OlgaGan
I need to just open AutoCAD without the palette panel.
0 Me gusta
ChicagoLooper
@OlgaGan
Try this:
1. Click Manage tab ChicagoLooper_0-1711005228183.gif Customization panel ChicagoLooper_1-1711005228184.gifUser InterfaceChicagoLooper_2-1711005228184.png
2. In the Customize tab, Customizations In <file name> pane, expand Workspaces, and select the workspace containing the palette that you want to modify.IMG_1988.jpeg
3. In the Workspace Contents pane, click the plus sign (+) next to Palettes to expand it.
4. Select the palette that you want to modify.
5. In the Properties pane=>TOOL PALETTE=>In the Show Box, select NO.
Chicagolooper
0 Me gusta
Valentin-WSP
@OlgaGan ,
Try and Cycle through the one you want.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
TheCADnoob
Solución aceptada
The tool paletts are a part of the workspace. You can change the workspace by opening palette or closing them. Once you have your workspace set up how you like it, you can save that workspace. Next time AutoCAD opens in that workspace, it will be configured how you want it.
Or if you prefer to have AutoCAD open the same way you left it every time you make a change, you can click on workspace settings. Then select Automatically save workspace changes.
CADnoob
