Anuncios
Latest 2020 update and xref text is masked in black
No aplicable
HI,
Just did the latest 2020 update and opened a drawing I was working in previously and the mtext from one xref is now masked out in model and paper space.  On another xref in the same drawing the mtext is fine but the text is masked out (not in the actual cad file of the xref).  I have gone into the first xref to make sure masking is a 'no' on the mtext properties.  However I cant work out why it would mask normal text which does not have that option unless its an issue with the main cad file.  Appreciate any help.seahorse.jpg
0 Me gusta
Responder
316 Vistas
1 Respuesta
Respuesta (1)
cadffm
Known issue for 2020.1 and fixed in tge next update.
You can unistall the 2020.1 update or you can edit the Text in the (xref) file.
If you like to know how, ask for it.
(I need take a look in my papers)
EDIT:
Your XYZ- XREF-Scale is not 1 1 1 right?
Your Z-Scale is not 1 right?
Perhaps you are lucky and re-set the XREF  Z-Scale  to 1 fix the problem.
:cara_guiñando_un_ojo:
Sebastian
0 Me gusta
