From my experience file sizes larger then 300-500 MB are for Autocad even on fast computers with 32 GB RAM impossible to open. (Frozen for hours like 1 or 2 and only kill helps). If smaller 3d file is open (150 MB like) its impossible to rotate view or so.. or work with. Its just Autoicad. Sorry not designed for LARGE FILES. (or with 3d mesh inside)
The only solution is to have Bentleys Microstation. Microatation can read plenty of 3d file formats and mainly DWG. After open and save to DGN all is 10x or 50 times faster. You can zoom rotate even model what was 900 MB in Autocad. DGN file size reduces its size 3-4 times so ending with file.
My recomendation when you need section ar generate hidden lines ... No Autocad could do it. (even program like Rhinoceros failed in opening such large file sizes)
Byt Microstation works. Generating such can take few hours but its done.
(There are some exceptions when it fails too, honestly I realized this failes too, but 99% it works).
I am really sorry but this situation prolonges all the time since Autocad beginnings. All past 30 years cam Microstation (nowadays they call it Bentley Open Building Designer) handle super large 3d and 2d projects and Autocad can not. Good luck. I know the way.
Example from real life:
same file in Autocad has 623 MB and in Microstation 178 MB.
(Microstation opens it when converted into DGN in 60 sec. Zoom all in about 8 sec.)
(I don´t remember already what time it took to Convert it from DWG to DGN but it could be in a range 15 to 30 minutes)
