Hello there!
Im currently working with the newest versions of autoCAD home, but in my office we work with the 2011 version.
One thing I quickly noticed since upgrading is that the latest commands used in the command line quickly vanish from the screen. I really would like to keep at least the latest 3 or 5 commands used in the screen, without having to expand the command line hystory to see them (or the results of the commands, like in the "area" command)...
Is it possible to set a little portion of the command line hystory so that it never vanishes from the screen? If so, can we set the number of commands or results to fix on the screen?
Thanks a lot!
Solved by GrantsPirate. Go to Solution.
Dock the command line if it isn't, then drag it up to expose 3 to 5 lines.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thanks a lot @GrantsPirate !!!
It was so simple, and you can even stretch it to show as many lines as you want...
Thank you!
