Joining lines and arcs
No aplicable
Anyone please help me to join the line & arc and also explain how. I have tried lots of time using peedit, fillet, flatten & overkill commands but didnt get result. Kind of these situation I draw new polyline over those but i am not satisfying with this.
0 Me gusta
Responder
3.418 Vistas
4 Respuestas
Respuestas (4)
3wood
1. Command: CONVERT
2. Command: EXPLODE (Explode mainly the polyline with the arc)
2. Command: FLATTEN
3. Command: JOIN (You may need drag end grip of the arc to end of the polyline first)
Result as attached,
rkmcswain
List the objects.
The red polyline has an extrusion direction or -1 in the Z axis.
LWPOLYLINE  Layer: "Level 41"
                            Space: Model space
                   Color: 1 (red)    Linetype: "BYBLOCK"
                   LineWeight: 0.40 mm
                   Handle = 2f0
              Open
    Constant width    0.0000
Extrusion direction relative to UCS:
                   X=   0.0000  Y=   0.0000  Z=  -1.0000
              area   709.5730
            length   278.9087
          at point  X=350360.9444  Y=2637496.2227  Z=   0.0000
             bulge    0.0274
            center  X=347815.1196  Y=2637555.8389  Z=   0.0000
            radius 2546.5227
       start angle       181
         end angle       188
          at point  X=350339.1736  Y=2637218.3047  Z=   0.0000
The JOIN command (AutoCAD 2006+) will join these two, but the result is a SPLINE
I'd say it's better to fix the red polyline, then join them as a single polyline.
0 Me gusta
rkmcswain
1. Nothing to Convert, they are already LWPOLYLINES. Plus that command will be N/A in the OP's version of AutoCAD (presuming he/she is posting in the correct forum).
0 Me gusta
No aplicable
Thanks for ur quick help dears,
I just EXPLODE both lines and used FLATTEN command then connected all lines by using JOIN command.
It's working...now  see the attached.
Thanks and thanks a lot.
0 Me gusta
