Join more polylines to one
No aplicable
Dear Community,
I would like to ask for your support. I have a .dwg and I would like to join the polilynes into one shape. I tried several methods but none of them worked. May I ask you to please support me how can I do it? Attached my file.
Thank you,
Máté
Responder
1.673 Vistas
9 Respuestas
Respuestas (9)
BeKirra
Command pedit is what your are looking for.
Select the option join to join all polylines into one piece.
All you have to ensure is endpoints of 2 polyline segments meets perfectly otherwise they would not be joined into one.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
Patchy
0 Me gusta
ennujozlagam
or you can type in your command prompt BOUNDARY > select pick points > pick inside your objects. thanks
0 Me gusta
tboehler
..or Join.  Or LINEWORKSHRINKWRAP.
If joining (PEDIT or Join) all lines/polylines must have same elevation and have matching endpoints (exact).
0 Me gusta
No aplicable
Dear guys,
Thank you so much for the support. I am using Autocad 2010 but the PEDIT didn't work. Anyway thank you so much for the upload I will use that file. On the other hand, I will try the other methods whenever I will have possibility to use a newer version. Can you please let me know your method? What did you do to reach that result you uploaded?
Thank you.
0 Me gusta
No aplicable
Can you please let me know your method? Thanks for your great help.
0 Me gusta
Patchy
There are a few lines with zero length and overlapped that's why you can't join them.
Explode all the polylines , then use command OVERKILL, then use Pedit, multiple, then Join.
BeKirra
OP mentioned the command pedit can't be used.
@Anonymous Can you give more details?
X² + Y² = C²
0 Me gusta
Patchy
PEDIT doesn't work if it has 2 zero length in there.
Have you even tested it out yet?
Have a look if you want:
0 Me gusta
