I want to join the lines forming each of these curved shapes. But I am not able to do so because of the error. When I zoom into the corners, the lines appear to be closed, but still I am not able to join. Please help.
Solved by Patchy. Go to Solution.
They're not all in the same plane. Getting the Surfaces out of the way, and looking from a 3D view direction:
Thanks, it worked.
For reference, people facing same issue can refer to https://forums.autodesk.com/t5/autocad-forum/cannot-export-to-stl/m-p/12250699#M1115394
