jitter style will not print in black and white
I was recently upgraded to 2017 full Autocad from LT 2013 (yeah!) and have been discovering new tools and techniques. Remembering the Squiggle tool that was never available in LT I was looking for a way to add a hand-drawn effect to a floorplan. A co-worker told me about creating styles using the Visual Styles Palette.
Perfect, just what I needed. The only problem is when I try to print the drawing I cannot get it print black and white. It doesn't matter which plot style is selected the preview always shows the layer colors. Doesn't matter if it is a standard plot style or one we have created. This only happens in the layout where the new style was applied.
I can print to a black and white printer and the lineweights appear correct but I need to print these as a pdf so will have to open them in another program to change all the lines to black.
pendean
Community Legend
Community Legend
Change your layer /object colors to 7 and try it again: use of STB plot style tables eliminate the need to rely on layer or object colors for lineweights too.
Nope, all of our plot styles are set to color 7.
pendean
Community Legend
Community Legend
But you are using CTBs: I'm suggesting a change to STB OR changing all on screen colors to 7 (not the blues and reds and greens I see in your screenshot).
Read all about both http://www.caddmanager.com/CMB/2009/08/cad-standards-ctb-vs-stb/
The visual style you are using ignores plot style table settings based on color: it might ignore STB too but you'll have to test it.
EDIT: I should add that if this is an actual business need (for client show-and-tell), ask to be upgraded to AutoCAD Architecture (not just plain AutoCAD). it has the best working option for this style of presentation drawing called NAPKIN SKETCH https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
I am again testing out use of Visual Styles. As to your comment about switching form ctb to stb I honestly don't know what you are referencing. Our office used a fixed format of preset templates so it is not within my control to enforce a major change even if I understood the differences.
The question still remains  - why or what is happening within the Visual Styles command that it completely overrides the pen settings and previews and prints using the layer colors? Is this a bug that I should report? Or is it a prerequisite of using Visual Styles?
GrantsPirate
In the Visual Styles Manager for sketchy, change Occluded Edges to yes for Show, and Color, White.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
ScottRoth
I have same issues, only in sketchy does the plot come out in color. I tried changing the occluded edges to show "yes" and color "white", line type "solid" and still previews in color. Is there a solution for this? The company ctb is preset for converting color lines to correct line weights in black/white - it works for other visual styles (2D wireframe is the default) but as soon I change it to sketchy - it doesn't work.
