issue with units when zoomed in or out
Message 1 of 9
 when we zoom in or out then how can we know  what is the dimensions of one grid
Replies (8)
Message 2 of 9
imadHabash
Hi and Welcome to AutoCAD Forum,
>> when we zoom in or out then how can we know  what is the dimensions of one grid <<
you can understand and control all the procedure ( grid spacing ) from DSETTINGS command. see below image . also for more information please read this link . >> Click <<
Imad Habash
Message 3 of 9
when we zoom out grid dimensions change then how to know what is the grid dimension
Message 4 of 9
imadHabash
then try to untick Adaptive grid to make the grid look fixed when zooming . as seen from my first post every grid ( x,y ) has a space distance that your elements will depend on those spaces . every grid is 10 x 10 units ( you can change the value ) so if you draw 5 grids then your line will be 50 length units.
Imad Habash
Message 5 of 9
Is there anyway to know grid dim with adaptive tick is in on mode
Message 6 of 9
imadHabash
>> Is there anyway to know grid dim with adaptive tick is in on mode <<
as i said previously the grid dim ( GRIDUNIT ) spaces could be known and control from DSETTINGS command. isn't it ?
Imad Habash
Message 7 of 9
can you find out difference between the below given pictures, which grid have what dimensions, and i used centimeters as units
one of the line is 10cm, and other is 100cm
Message 8 of 9
Alfred.NESWADBA
No, not just from looking to the screenshot. You can use command _DIST and show 2 grid points to know the raster distance.
Why do you need the grid? Either you are doing some schematics then turn off adaptive grid or you even don't need a grid, do you? Maybe we understand your needs of grid better when you describe some background info...
When I turn on grid then I only use it for orientation in 3D to see the XY plane, the distance is irrelevant for me.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 9 of 9
imadHabash
The idea from using GRIDS is to make and prepare lines as a grid with known distances . now you can stop changing grids when zooming by an option that we've mentioned above. at the same time you can use ( recommended ) the SNAP ( F9 ) option which will guide you and jump over the grid by also known distances ( snap spacing ) that controlled by you and as your need.
Imad Habash
