Anuncios
Issue with Inserting Saved Drawing into Layout tab
No aplicable
I want to take a title block that I have saved and import it into a drawing that's complete, but I can only get it to import into the model space. I want it to only show up in the Paperspace. Is there any way I can do this?
0 Me gusta
Responder
418 Vistas
8 Respuestas
Respuestas (8)
Patchy
Sounds like the layer to paste is off or freeze, it should work on both spaces.
0 Me gusta
sthompson1021
Could this be a problem with the scale of the title block? If you do a zoom extents in paper space after you insert the title block, does it show up?
0 Me gusta
rkmcswain
Is the title block drawing itself drawn in MS?
Maybe it's a scale or base point issue too.
R.K. McSwain     | CADpanacea | on twitter
0 Me gusta
No aplicable
When I paste it, it shows up. I just want it to show up on the layout tab and not the model.
0 Me gusta
pendean
Community Legend
Community Legend
Since you say copy/paste works, do this: instead of the just "pasting", use PASTEORIG command (paste to original coordinates), does it also vanish? If you use Zoom Extents does everything shrink?
0 Me gusta
sthompson1021
Can you explain how you are trying to insert the title block drawing? If you are in a layout and do not have model space active, there should be no way to paste it into model space.
0 Me gusta
Patchy
Did you paste the Title Block while in Paper Space but thru a viewport ?
0 Me gusta
cadffm
@dimarco
There is no magic with Layouts/Paperspace AS TARGET and Inserts.
(Only important: Command Insert get only the Modelspace of a DWG as Block if you try to insert a DWG as Block)
Without long descriptions:
- Check Layers in your Layout for VP freeze
- if titleblock is a annotativeBlock check annoscale or set ANNOALLVISIBLE
Sebastian
0 Me gusta
