Issue with creating surface
No aplicable
Hey,
So i am having a problem with creating surface of my object. I created main frame  and drew surface boundaries (in pink). When I try to use networksrf command, it says - Section is not sufficiently smooth.Any ideas? I need to lift this surface of this petal before i use polar array command... :cara_de_decepción:
0 Me gusta
Responder
Soluciones aceptadas (3)
691 Vistas
10 Respuestas
Respuestas (10)
leeminardi
Solución aceptada
First, JOIN the two line-arc-line edges into single polylines.  You can then use LOFT to yield a surface close to the  shape you want by selecting the 3 cross section and ignoring the end arcs.
lee.minardi
john.vellek
Solución aceptada
Hi @Anonymous,
I like @leeminardi's suggestion. I made a quick video to show the steps in action. I hope this works for you.
John Vellek
No aplicable
Wow thank you!!!
That was verry helpful indeed!
I successfully did that and polar arrayed 10 petals around center`s extruded circle :cara_con_una_leve_sonrisa: The only problem is I cannot do the same with the center circle (dome)
As You showed in video, two sides must be in polylines... I tired to simulate the same with center dome, by creating two arcs and spline... Lofting still wont work... what am I doing wrong.... All the videos of creating dome on Youtube are not very helpful because they either demonstrate it in old autocad or the video is without comments... x(((
0 Me gusta
leeminardi
Just revolve a closed shape like the following to create the dome.
lee.minardi
john.vellek
Solución aceptada
Hi @Anonymous,
The dome is very simple using @leeminardi's great suggestion. I show the process of using REVOLVE to create the shape. You could also use a sphere and slice if you want a different way to do this.
John Vellek
No aplicable
Wow Thanks!!! I managed to unite all pieces nice and neat!!! Now Only thing thats bugging me is that dome, i mean I tried to revolve it, I managed to convert spline into 1 polyline... It still wont revolve.. WHy is that? Last time, I somehow managed to do that, but I did not know what I did there in the first place...
0 Me gusta
john.vellek
Hi @Anonymous,
If you remove the vertical part of that profile I think you will be able to revolve and create the dome.
Here is another video to show that step.
John Vellek
0 Me gusta
No aplicable
Yes, i tried that, and it was successful, the only problem is that, i dont tink that its solid, because spline polyline is not closed boundary, am i correct? :cara_con_una_leve_sonrisa:
0 Me gusta
john.vellek
HI @Anonymous,
Let's try this.
Create a sphere with the correct diameter. Then create a rectangle. Move the rectangle's center to the center of the sphere. Now move it up straight up so that it is 7 down from the top of the sphere. Now use the rectangle as a reference for SLICE to cut off the bottom of the sphere. Does this work for you?
John Vellek
No aplicable
I had Idea like that, and I tried that.. Resulting dome doesnt align with base circle eddges - its too small :cara_con_una_leve_sonrisa: Maybe I can reshape it somehow?
0 Me gusta
