Issue with creating a surface in AutoCAD
Message 1 of 13
Hi ,  I have a 3D wireframe of a geodesic structure which I am trying to convert to a surface so I can generate the intersection profile of a second shape.  I just keep getting a message that xxx items cannot be converted, no matter what I try.  The really annoying thing is that I know I have done this before, a while back ,but can't remember how!  I am a 3D novice so any help in walking through this would be really appreciated!
@Anonymous
john.vellek has edited your subject line for clarity: Issue with creating a surface
Replies (12)
Message 2 of 13
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Have you tried giving the surface some thickness?  I would like to see your file if you can share it.
If your data needs to be private or confidential, please email it directly to me at [email protected] and please include a link to this thread in your email.
John Vellek
Message 3 of 13
Thanks for your response.  The problem is that I cannot create the surface to give it any thickness.  I have attached the file here - I hope.
thanks
Message 4 of 13
dieters
@Anonymous
To clarify your question, did you create a wireframe structure in 3D using only lines or polylines?
Dieter
Dieter Schlaepfer
Principal Learning Experience Designer
Autodesk, Inc.
San Rafael, California
Message 5 of 13
The wireframe is an export from Cadre Geo7 which is a geodesic generation program so it just exports each member as a 3D line, not polylines.
Jeff
Message 6 of 13
Patchy
My old autocad can get to 3d face but can't go UNION to make a whole dish.
Message 7 of 13
john.vellek
HI @Anonymous,
I was able to isolate all the 3DfACES and use CONVTOSURFACE. I was then able to use Union to connect them all into a single surface. I was also able to convert to a mesh.  Perhaps this will get you further along.
John Vellek
Message 8 of 13
dieters
@Anonymous, @Patchy, @john.vellek
From there, take a look at these Help topics:
AutoCAD 2019 Help: To Create a Solid by Offsetting a Surface
https://help.autodesk.com/view/ACD/2019/ENU/index.html?guid=GUID-72C2824A-4895-4CDD-87BF-7ED26199F9D...
AutoCAD 2019 Help: About Converting Surfaces and Meshes to 3D Solids
https://help.autodesk.com/view/ACD/2019/ENU/index.html?guid=GUID-FABC5079-9078-468A-8AAD-E61FEAD7381...
Dieter
Dieter Schlaepfer
Autodesk, Inc.
Message 9 of 13
Yes,  I have the same problem,  I cannot join the individual planes together into one surface.  I thought I could use SURFBLEND but I cannot select any of the triangles so it does not recognize them as surfaces.
Jeff
Message 10 of 13
Patchy
Message 11 of 13
Hi John, sorry,  my last post crossed with yours , but,  wow,  that's great.  Would you be able to give me the steps you took to get here as I tried using CONVTOSURFACE.
jeff
Message 12 of 13
john.vellek
Hi @Jeff.hebel,
I made a quick video for you that shows my steps.  I first try to isolate the 3Dfaces from the line work.  I do this by using Qselect.
I then use the CONVtoSURFACE command which changes each face into a surface. Then, I use UNION to combine them into a single surface.
John Vellek
Message 13 of 13
Thanks so much John,  think I am good to go,  but I am sure I will be back as this advances!
Jeff
