Issue with 1660ti on AutoCAD 2022
unknownuserblank
Message 1 of 44
unknownuserblank
I have been experiencing slow mouse movement issue on new AutoCAD 2022. on AutoCAD 2021 or 2020 it works fine without problems. I even reinstalled windows and autocad 2022... Still nothing works. All drivers are uptodate.
When i start autocad 2022 with Intel UHD Graphics no problems. But with nvidia 1660ti i have slow mouse movement.
If i disable hardware acceleration to off mouse is back to normal but I don't want to do it because the image is distorted.
So i want to keep using 1660ti like before. any solutions?
Replies (43)
Message 21 of 44
G.Frodl8151
Observer
Observer
thanks a lot
Message 22 of 44
nrz13
The article says that "starting with AutoCAD 2017, the program requires DirectX 11 by default".
My question is, if that is indeed the case, why doesn't the installation for AutoCAD automatically set this configuration?  I vaguely recall having to manually set my computer to DX11 manually when I first set up this computer a few years ago.  Does everyone need to manually adjust this, or does AutoCAD try to set it, and all who have had this problem have experienced some glitch where the installer didn't set it right?
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 23 of 44
unknownuserblank
autocad 2022 using directx 12. older versions used directx 11.. since its the first time they used it in autocad. they (autodesk) or nvidia or microsoft needs to update or fix things. no one have to adjust anything at enduser this is not a UI configuration it is a problem at core.
btw i did not accepted those things as solutions. they are just workarounds...
Message 24 of 44
pendean
Community Legend
Community Legend
>>>...btw i did not accepted those things as solution...<<<
Do something about it then other than posting in the forums where it only stays between use end users:
Here https://www.autodesk.com/company/contact-us/product-feedback
and Here after you click on the ? icon for "post installation support" https://manage.autodesk.com/home/
Message 25 of 44
unknownuserblank
i already reported to autodesk/nvidia/microsoft the day i created this thread.
autodesk: no reply yet
microsoft: auto reply that they said will investigate
nvidia: replied, they asked me to test their new driver, did not work i replied back, they thanked and said they are going to work on it. (i also told them its about directx 12)
soo i did my part
Message 26 of 44
pendean
Community Legend
Community Legend
Good to know.
Message 27 of 44
Justin_Doughty
I've had a reply from Autodesk, they are aware and are working on it with NVIDIA/DX12.
Justin Doughty
ARKANCE
Message 28 of 44
elzohry2007
That's awesome
Message 29 of 44
unknownuserblank
They launched an update for autocad and guess what issue is not solved...
Message 30 of 44
Microsoft just updated .NET Core ("new" NET Frameworks DX12 that come with AutoCAD 2022). FYI problem still persist.
Message 31 of 44
unknownuserblank
yes not solved by microsoft or autodesk, fingers crossed for nvidia... btw what about amd? are there any problems about amd
Message 32 of 44
ZHUKOV_ING
Yes, definitly the problem is with DX12, BUT.
I have dual setup monitors, U21412 (1080p) and P2720 (1440p)...
With DX12 autocad 2022 runs smooth only on my 1080p monitor.
With DX11 autocad 2022 runs smoont on both monitors but the new GSF shaded mode is not stable...
Message 33 of 44
prousseauCQJ6U
Thank you very much, I had the same problem (input lag when using Hardware Acceleration on a Nvidia 3080). Now it's fixed! For anyone reading this, I fixed it running the GFXDX12 command and changing its value to 0.
Message 34 of 44
jflynnCXA68
Like others in this thread, my up-to-date Windows 10 and NVidia drivers on my Quadro T2000 also experience this issue. Thank you for the GFXDX12=0 fix, which seems like the best option (over the environment variable change shown in the help article...)
Message 35 of 44
unknownuserblank
no use gfxdx12 = 0 its easier method
Message 36 of 44
jflynnCXA68
I was saying I agree with that; edited above for clarity
Message 37 of 44
sandris.metlovs
Tnx helps a lot 🙂 tough my grahic card is bad.
Message 38 of 44
Message 39 of 44
jflynnCXA68
Yes, there is a an official workaround using system environment variables. However, not all users have the permissions to modify these variables, so Justin's method using AutoCAD's own variables is easier for users to execute:
https://forums.autodesk.com/t5/autocad-forum/issue-with-1660ti-on-autocad-2022/m-p/10198559/highligh...
Message 40 of 44
Yeah, ofc. Just FYI, 2022.0.1 and GFX beta update didn't solve issue, already tried.
