Isometric drawing
linay_vanarose
Isometric drawing
linay_vanarose
When I turn this plan to isometric it automatically creates this vertical lines. Is there a way to turn it off or remove it?
0 Me gusta
Responder
408 Vistas
5 Respuestas
Respuestas (5)
j.palmeL29YX
Not the isometric view "creates" these vertical lines, but someone somewhen created 3D Objects, which we can see now.
To analyze what really is going on (and how to repair it) post the dwg file please.
Jürgen Palme
Washingtonn
Select one of the objects and then in the Properties palette under General, Check the thickness setting.......
0 Me gusta
linay_vanarose
Here's the DWG file. I also tried to explode and just delete the vertical lines but it cannot be exploded either.
0 Me gusta
cadffm
Select all, set thickness to 0
For modelspace and inside all blocks (use BEDIT to edit blocks), for example inside this block with the senseful name SDGSFGDSG or A$C33E27A70 aso.
Whileobjects selected, inside the properties pallet [CTRL]+[1], change the object type to LINE and change THICKNESS to 0,
change object type to ARC and change THICKNESS to 0,
and so on.
Foreach object type
(don't forget you blocks, you can edit the block content by using command BEDIT)
Sebastian
j.palmeL29YX
Set all element's (also inside of block definitions) thickness to 0, move all objects wich are not drawn in the XY plane to Z=0, clean the file using the OVERKILL command, ... a lot of work (not all is shown in the video).
Attached the result.
Jürgen Palme
0 Me gusta
