I have some doors blocks created in cm, on layer 0, all byblock except the opening arc and ending position of the leaf that are ACAD_ISO02W100.
When I insert (and scale) them in a drawing in meters, the iso-dashed lines are all visible, but when I print it the dashed arcs are not printed in the pdf (the lines are!). What the hell is happening?
Note: all the dashed elements are in the same layer, with the same dash scale, I also managed to print an ellipse's arc but not the standard arcs!
acad screenshot
outputted pdf screenshot.
Bug? Please help!
acad 2019.1.1 on win 10
Solved by imadHabash. Go to Solution.
Solved by sophia_lee. Go to Solution.
HI @boicottms ,
I have tested your file from AutoCAD 2019.1.2 and 2020.1.2 and couldn't reproduce the problem. please try below steps and see if this helps.
Hope this is helpful. kindly 'Accept as solution' if this helps. Thank you,
i test your drawing and there is NO problem !!! i suggest to change your DWG To PDF.pc3 by the attached one .
Imad Habash
