ISO-25 dimension style is missing in my new AutoCAD installation when i installed in one laptop and is installed properly in another laptop which uses the same license. I want the ISO-25 dimension style to show in both laptops. What should i do? Thank you. Please see screenshot.
Solved by rimuka34. Go to Solution.
Solved by imadHabash. Go to Solution.
it depends on your used template .... from Ctrl+N select acadiso.dwt , any changes ?
