Hello @Waseem_Dabbas
Did the post by @imadHabash and @R_Tweed helped you and answered your question?
To give you alternative steps:
1. Create an empty drawing which contains all your layouts. You could call it layout library to make the name more speaking
2. Once you need the layouts from the drawing, click with the right mouse click and select "From template"
3. Select the layouts you want to import
4. The selected layouts will be imported in your current drawing.
Transforming this to your scenario - you could have a layout library drawing for each of the 20 layouts and import / delete them when needed.
In case your question got answered, feel free to click on the button "Mark as Solution"next to the post that helped. Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
