Is there a way to save customized layout background color to a file?
iiiaha
Message 1 of 8
iiiaha
Hi.
I usually use layout tab for drawing. And, I changed the layout background color to black in CAD option.
The problem is, when I send a file to another, the reciever's layout background color is grey(default color setting).
So I should let them know how to change the background color step by step. (most of them don't know that)
It is quite bothering so I wander there is a way to save my personal option settings into a file for sharing.
Thank you in advance.
Replies (7)
Message 2 of 8
paullimapa
You can provide them a link to run this lisp code that lets them easily pick a background color
Paul Li
IT Specialist
@The Office
Message 3 of 8
iiiaha
Thank you Paul.
you mean, using that lisp code, making a lisp file(.lsp), and sending it with dwg file?
but the receivers don't know about lisp at all. they can't load or apply lisp files. it should be hard for them.
Or, Is there a easy way to apply certain lisp file by just clicking a lisp file?
Message 4 of 8
paullimapa
The lisp file like a dwg file needs to be saved to a folder and in this case call it CBSet.lsp. Then it’s as simple as dragging and dropping it into your AutoCAD drawing area. Next enter at the AutoCAD command prompt CBSet to run the code. Give it a try and let me know what you think.
Paul Li
IT Specialist
@The Office
Message 5 of 8
iiiaha
OK. I will try it. Thank you for your advice.
Message 6 of 8
cadffm
so it isn't possible, you can save personal settings inside your .dwg.
"I should let them know how"
Good idea, but think about - that's a usual problem we all have. Nothing special.
Solution: Communication, teaching
and if it is very needed:
Add a Text on non-printable Layer inside your DWG. Fir example, above the title.
Sebastian
Message 7 of 8
Valentin_CAD
@iiiaha ,
Background color is an "individual setting".
Consider sharing the link or creating an AutoCAD Profile.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 8 of 8
paullimapa
Glad to have helped….cheers!!!
Paul Li
IT Specialist
@The Office
