Is There A Way To Mass Import Latitude/Longitude Points From Google Earth Pro?
mdarien4AQ94
mdarien4AQ94
My question is in the title, I am simply looking for a way to mass import lat-long points from Google Earth Pro instead of having to manually add each one using the 'Mark Position' > 'Lat-Long' option in Geolocation.
I am importing underground utility markings, and well, there's a lot of points to add manually. There has to be a simpler and quicker method. Is there?
0 Me gusta
Responder
Soluciones aceptadas (1)
953 Vistas
12 Respuestas
Respuestas (12)
Pointdump
Hi Mason,
If you have Map 3D or Civil 3D you can use Command MAPIMPORT to import all those points.
If you have Vanilla AutoCAD, look to 3rd party apps.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
0 Me gusta
mdarien4AQ94
Understood. That's what I was hoping to avoid. Looks like it'll be manually adding each point for me.
0 Me gusta
pendean
Community Legend
Community Legend
@mdarien4AQ94 if you are a an active paying subscriber to plain AutoCAD, AutoCADMAP3D is only a free download away for you to install and use https://manage.autodesk.com/products/MAP?version=2023&platform=WIN64&language=EINT
0 Me gusta
mdarien4AQ94
I understand that, I'm just not a fan of downloading another software just so I can use a single feature every now and then.
0 Me gusta
pendean
Community Legend
Community Legend
@mdarien4AQ94 Very shortsighted for the year 2023 especially when you are already paying for 6-other AutoCAD variants with your subscription, but it's your time/money to spend doing it any way you want of course.
Happy Cadding.
0 Me gusta
mdarien4AQ94
Alright, so out of not wanting to be called shortsighted, I downloaded Map 3D and tried importing my points from a .kmz file. The points in Map 3D were set way off from where their lat/long points are on google earth pro, as well as not being scaled properly. Do you have any advice towards how to fix that?
0 Me gusta
Pointdump
Hi Mason,
Alrighty then! Let's see what you've got. Please post your KMZ. (You might need to zip)
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
mdarien4AQ94
I sadly can't upload the files directly due to company policy, but I can show the settings I've got and walk through it all.
Below I've snipped the AutoCAD Map 3D settings for MAPIMPORT as well as the Google Earth Pro existing settings.
For the AutoCAD settings, I noticed that the input coordinate system uploads as something different than my current drawing coordinate system. I went through and changed all of these to match the current drawing coordinate system. That import showed the points being within a few hundred feet of where they should be in AutoCAD, but they were still off, and still scaled way off. I went back to Google Earth Pro and got the Lat/Long of 2 points, and I manually added those positions into AutoCAD and scaled. I ended up needing to rotate my points, and that got them very close together but not quite perfect still. There's something off between the actual Lat/Long numbers and what happens to them when importing.
0 Me gusta
pendean
Community Legend
Community Legend
Is your issue one of units perhaps?
You draft in inches or mm, civil/map folks use feet or meters or… but never mm nor inches!
0 Me gusta
mdarien4AQ94
My drafting is in inches/feet. Below is what my drawing units are set to.
0 Me gusta
TerryDotson
0 Me gusta
Pointdump
Solución aceptada
Hi Mason,
Map 3D doesn't like Architectural Units. Use Meters or Feet. And as a general rule, Unitless works best for Insertion Scale in UNITS.
Since you couldn't post your KMZ, I'll post one. Start with an Imperial (US Survey Foot) Template and use MAPCSASSIGN to assign NV83-EF coordinate system. Use MAPIMPORT, and then _GEOMAP. Compare placement to Google Earth Pro.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
