Is there a way to disable AutoCAD text from becoming comments in Adobe PDF?
Hey all, I was wondering if there is a way to prevent AutoCAD txt from becoming a comment in Adobe Acrobat Pro
When it shows up as a comment then the PDF is extremely slow to load even on a higher end PC...
I've already tried the PDFSHX command and put the value to 0 but it doesn't seem to work.
Any help would be greatly appreciated!
pendean
Community Legend
Community Legend
Unable to replicate your issue.
Share/post your problem PDF file with the problem and a portion of your DWG file that created that PDF with SHX fonts in use.
rkmcswain
So you've seen this and already done it?
What do you mean by "it doesn't seem to work"?
R.K. McSwain     | CADpanacea | on twitter
jggerth
Easiest way is to quit using .SHX format fonts. and switch to TrueType.
