Is there a way of visualising only block inserts?
oransen
oransen
Maybe a silly question, but is there a way to visualize only block inserts? Like layers but freezing other object types?
0 Me gusta
Responder
Soluciones aceptadas (2)
585 Vistas
10 Respuestas
Respuestas (10)
cadffm
Nothing to do with block inserts but also usable for your goal, Command: ISOLATEOBJECTS or HIDEOBJECTS
read all about the commands, settings and variable in your help [F1]
Sebastian
oransen
Thanks for the reply, I did not know that command existed!
Unfortunately there are 100s of objects I'd need to isolate...  :cara_de_decepción:
But thanks anyway.
0 Me gusta
ilia.borisov
Solución aceptada
cadffm
And what is the difference between 30 and 3000 ?
Selectsimilar(selectsimilarmode)
QSelect
Filter
SSX  ENTITY INSERT
(sssetfirst nil (ssget "_X" (list'(0 . "INSERT")(cons 410 (getvar 'CTAB)))))
Sebastian
0 Me gusta
oransen
"And what is the difference between 30 and 3000 ?"
Oh, about 2970 I'd say.
I need the selection without using AutoLISP etc., it is not for me.
0 Me gusta
oransen
As far as I can tell that command does not allow me to, for example, only select lines or circles or block inserts. :cara_de_decepción:
0 Me gusta
ВeekeeCZ
Solución aceptada
SELECTSIMILAR has a setting.
Command: SELECTSIMILAR
Select objects or [SEttings]: ...
If you turn off all the options, it will filter objects just by object type (= all blocks if you pick one).
The setting is stored in SELECTSIMILARMODE.
0 is for no properties (as you want now), 255 for all properties (default).
oransen
Magic, thanks for that. :cara_con_una_leve_sonrisa:
(It would have been clearer if they'd had an entitytype check box though...)
0 Me gusta
RobDraw
Your selection = the check box.
There is also QSelect for targeting a selection.
There are several ways to select what you want so that you can apply the isolate object command.
Rob
0 Me gusta
ВeekeeCZ
This option would be definitely useful. We could have select across entity types easily (EQ all objects in the layer).
