HI @Anonymous,
According to @dbroad's clever and stealthy approach, 4000 characters seems to be the limitation.
Is there a reason you can't create a block with revision information to contain all of this?
For instance, your revision schedule in your drawing might contain a block called rev tag.
Rev Tag could have attributes to have No, Date, RevInfo, Comments with the comments section hidden and set to multi-line if necessary.
Then you could export using the data extract at every revision Publish date the list into a spreadsheet that you can keep with the project files and folder.
This way your information can be stored on each layout (in case you issue different sheets at different times).
Just a thought
John Vellek
