Hello, I need to draw the wings of a cicada or dragonfly using a Voronoi diagram in AutoCAD, but doing it by hand takes too much time, so I am asking the community.
Is there a LISP that can generate dragonfly wings or cicada wings? Or do you have a dwg drawing for this?
It's hard to find by Googling...
Solved by pendean. Go to Solution.
Solved by TheCADnoob. Go to Solution.
Solved by Valentin-WSP. Go to Solution.
@Quasar_Park wrote:Hello, I need to draw the wings of a cicada or dragonfly using a Voronoi diagram in AutoCAD,...
Check this one:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
I was able to get to this with just a little cleanup
I used the lisp found here on reply # 10
https://www.theswamp.org/index.php?topic=45085.0;nowap
CADnoob
the OP has already rejected most of the content found on the web, including your excellent find, see their other post on the topic
@pendean wrote:
@TheCADnoob wrote:
I was able to g...
...https://www.theswamp.org/index.php?topic=45085.0;nowap
I guess the main difference between this post and that is that the OP doesnt want to draw the random points. Either way... in the grand scheme of not wanting to draw things manually this lisp is pretty awesome for doing a Voronoi. I wonder if the OP is having problems drawing the points..
CADnoob
Agreed!
