AutoCAD Forum
Is there a LISP that can generate dragonfly wing or cicada wing? Or is there a dwg drawing of these?
7 REPLIES 7
Message 1 of 8
Quasar_Park
470 Views, 7 Replies
Hello, I need to draw the wings of a cicada or dragonfly using a Voronoi diagram in AutoCAD, but doing it by hand takes too much time, so I am asking the community.
Is there a LISP that can generate dragonfly wings or cicada wings? Or do you have a dwg drawing for this?
It's hard to find by Googling...
7 REPLIES 7
Message 2 of 8
Valentin-WSP
in reply to: Quasar_Park
@Quasar_Park ,
@Quasar_Park wrote:
Hello, I need to draw the wings of a cicada or dragonfly using a Voronoi diagram in AutoCAD,...
Check this one:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 3 of 8
TheCADnoob
I was able to get to this with just a little cleanup
I used the lisp found here on reply # 10
https://www.theswamp.org/index.php?topic=45085.0;nowap
CADnoob
Message 4 of 8
pendean
in reply to: TheCADnoob
the OP has already rejected most of the content found on the web, including your excellent find, see their other post on the topic
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/can-i-get-autolisp-to-create-a-voron...
Message 5 of 8
TheCADnoob
in reply to: pendean
@pendean wrote:
@TheCADnoob wrote:
I was able to g...
...https://www.theswamp.org/index.php?topic=45085.0;nowap
I guess the main difference between this post and that is that the OP doesnt want to draw the random points. Either way... in the grand scheme of not wanting to draw things manually this lisp is pretty awesome for doing a Voronoi. I wonder if the OP is having problems drawing the points..
CADnoob
Message 6 of 8
pendean
Agreed!
Message 7 of 8
pendean
New pot that combines all others into one if anyone needs it
https://www.cadforum.cz/en/voronoi-diagrams-in-autocad-tip14017
Message 8 of 8
Quasar_Park
This is really beautiful.
You showed me something I couldn't find at all.
Thank you so much. I really mean it.
Forma Design Contest
