inverted texts, dimensions, attributes
abhima_av
abhima_av
hello, actually i am facing a problem that in a perticuler drawing after coping content from perticuler to other  all the dimensions, texts and attributes are becoming horizontally flipped, ere iam attaching a reference image for the same, kindly reply with the solution ASAP.
tramber
I can see the Y axe going to the left.
Please try the PLAN command followed by a double ENTER.
It will give the planar view to the UCS by the correct position above it, if you want....
-didier-
Bonjour @abhima_av
I think your view of the drawing is mirrored.
When you will be back in the general UCS everything will come back in the right order.
Command "PLAN" valid valid
Remember that if you mirror with texts, MIRRTEXT must be set to 0 (zero) so as not to mirror the texts.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
abhima_av
Thank you for the valuable reply sir, i tried your solution, yes the original drawing is done with flipped UCS, and as per your solution i executed "PLAN" command, and yes the UCS got corrected but original drawing flipped, and i tried coping flipped text to another right UCS drawing the result is flipped only. ( here is a attachment of plan command executed drawing )
tramber
We didn't correct the UCS. (Maybe it is the GCS that is on.) We changed our point of view.
To flip text or not with the Miror(s) command, you need to set MIRRTEXT to your convenience, as said.
