- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello all,
I am working in AutoCAD LT 2019. I have file A (GROUND FLOOR), xref'ed into file B (GROUND FLOOR_Group A), and file B xref'ed into file C (Sheet file).
The problem I am having is that when I try to Xref file B into my sheet file (or even new files) I often get the invalid error message below:
So I have used the recover all command, -purge (regapps), -purge (all), and audit on both files A & B. I have even wblock both the files and the issue is temporarily fixed, but then it comes back within a matter of 15/30 mins. I must also add that whenever I Xref file B into the sheets it is making the saving process SUPER slow.
I am attaching files A & B to this post in hopes that someone can please help me. My best guess would be that there is a rogue block or symbol that gets purged but keeps coming back... I am on a deadline in an office that has no in-house CAD support, so this is kind of my last attempt at fixing this issue after having searched the forums with no luck finding a solution to the same issue I am having.
Thank you very much in advance for any help, suggestion, or scrubbing of this file. I wouldn't know where to start to look for the corruption in it...
¡Resuelto! Ir a solución.
