>> No Solutions as yet !!
Can you please let us know which of the above suggestions you have tried and which result you have got?
Just saying "nothing helped" does not bring us into a situation to better know what happened in your system ... but that is needed to give valid suggestions.
E.g. what happened when you created a new PC3 ... ?
Let me also add 2 sentences to that statement from your first post:
>> nothing changed over the last 2 years except I updated from A14 to A17 6 months ago !!
There does not exist any single system on the world, based on Windows, that is unchanged for 2 years (except it is switched off)
As you installed AutoCAD 2017 a lot of system parts have changed, I would say hundreds of files are changed/added to the operating system with that installation. That means it is quite possible for you to update drivers as well (display, printer, plotter, ...)
>> I want to know why this unnecessary issue is happening
As this happens on your system we need info's about your system. That's how we can try to help 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
