Intersect on 3d corner in AutoCAD Model
No aplicable
I am trying to create a corner for molding on a rendering. I created a molding profile and joined the polylines. I then extruded the shape and copied it. I rotated the copy 90 degrees and aligned the two shapes. I have tried to intersect the two solids to create a 3D mitered corner. but the intersect command  does not intersect. The subtract and union command will not work on these shapes/solid either.
@Anonymous, john.vellek has edited your subject line for clarity:Interset command dose not work
0 Me gusta
Responder
Soluciones aceptadas (1)
883 Vistas
7 Respuestas
Respuestas (7)
Kent1Cooper
Solución aceptada
INTERSECT is not something like Fillet for Solids -- read about what it does in Help.  You probably want to SLICE them at the miter angle.
Kent Cooper, AIA
0 Me gusta
No aplicable
I will try slice. That is a good idea.
0 Me gusta
No aplicable
How about the Path option in the Extrude command?  Just make it all in one command.
0 Me gusta
john.vellek
Hi @Anonymous,
If the excellent suggestions here haven't helped you thus far, please attach your drawing so I can take a look for you.
John Vellek
0 Me gusta
JDMather
Are you sure you have 3D solid bodies?
0 Me gusta
No aplicable
Yes. The odd thing is that if the two objects are not aligned correctly the intersect will work, i.e. If the corners of the two objects are aligned at the same point I cannot intersect, but if one object sits below that point I get an intersected, all be it odd, object.
0 Me gusta
No aplicable
Thank you. I still cannot get a proper intersect but one user suggested I use the slice command and that worked great.
0 Me gusta
