Internal Error: dbspace.cpp@1796: eHandle Use
how can i fix this internal error in autocad 2017.
S.Faris
is the error happening during a specific task?
Try PURGE and AUDIT.
Close the file and Open it using RECOVER from Autocad-Drawing utilities menu.
Go through the command line to see if any errors are found.
SALMANUL FARIS
jayhar
Hi @Anonymous
1. You need to update AutoCAD 2017 Service Pack 1
2. use the DXFOUT command to save the file as a DXF and then use the DXFIN command to save the file back to DWG format
3. How to repair corrupt AutoCAD files.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Alfred.NESWADBA
Hi @jayhar
AutoCAD 2017 SP1 is not the latest update, the latest update is AutoCAD 2017.1.2
@Anonymous
When do you get this exception?
  • every time you start AutoCAD during the start process
  • sometimes when starting AutoCAD
  • sometimes with a specific drawing
  • every time with a specific command in a specific drawing
  • every time with a specific command in also new drawings?
The more details you give us the better the chance we can reply with valid suggestions!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
