Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Integrating ChatGPT / GPT-based AI into AutoCAD Looking for Advice or Existing Plugins
afloareirazvan
afloareirazvan
Hello everyone,
I’m exploring ways to integrate ChatGPT or other GPT-based AI tools directly into AutoCAD via an extension, plugin, or add-on.
My goal is to boost efficiency in my CAD workflows using AI/ML, whether that's for automation, design suggestions, code generation (AutoLISP/VBA/.NET), documentation, or intelligent prompts.
I’m open to:
  • Existing plugins or APIs that already enable GPT-AI integration in AutoCAD
  • Custom development advice (AutoLISP, .NET, Python, etc.) for connecting ChatGPT to AutoCAD
  • Machine learning use cases in CAD workflows (design analysis, drafting assistance, etc.)
  • General productivity tips using AI in civil/infrastructure design
I’d really appreciate any advice, sample projects, or insights from anyone who’s tried something similar.
Thank you!
RSomppi
What have you found so far?
pendean
Community Legend
Community Legend
@afloareirazvan good luck with that: you're about 10-years too early if you are just an end user and not inside/working at "chatgpt" and Autodesk. Apply to work there, it's where this is all happening:
https://www.autodesk.com/careers/overview
https://openai.com/careers/
In the meantime... don't dismiss CLAUDE, GEMINI, COPILOT and other AI offerings not publicly discussed in mass-media that are out there too: brand-names are not always the best option for specialty needs at the end of the day.
afloareirazvan
I've actually tried CLAUDE, GEMINI, and COPILOT and am currently focused on integrating AI into my workflow in a customized and specialized way, trained specifically on my processes.
My current approach and goals:
  • I'm exploring GPT-based models (like ChatGPT) to work alongside AutoCAD for:
    • Code generation (AutoLISP, VBA, .NET)
    • Smart drafting assistants
    • Automated documentation
    • Design logic support (e.g., rule-based validation, layer structuring, etc.)
Why I do not rely on general AI out of the box?
  • Generic models are powerful, but often lack contextual awareness of CAD standards, infrastructure norms, or workflow constraints in civil/public projects.
  • I see more value in fine-tuned assistants that understand the structure of my drawings, tags, and even naming conventions.
What I'm looking for:
  • Real-world examples or tools (plugins/APIs) integrating GPT or LLMs into AutoCAD directly
  • Best practices in connecting GPT via AutoLISP, .NET, or Python
  • Ideas on embedding local project knowledge into LLM prompts
  • Ways to optimize productivity in CAD through AI-driven scripting or suggestions
If anyone here has experimented with:
  • Prompt templates for drawing logic
  • Using ChatGPT to generate or debug LISP routines
  • Embedding metadata from drawings to enrich AI prompts
...I'd love to connect and exchange ideas.
afloareirazvan
What I’ve Found So Far
  1. Scripting Interfaces for AI Integration
    • AutoLISP: Ideal for automating repetitive CAD tasks; easy to generate and test code from AI prompts.
    • .NET API (C#/VB.NET): Enables deeper plugin development and custom commands inside AutoCAD.
    • Python (via pyautocad or COM interfaces): Allows external scripting and communication between AutoCAD and APIs like OpenAI.
  2. Tools and Libraries Used
    • OpenAI API: For generating code (AutoLISP, VBA, .NET), documentation, and intelligent prompts.
    • pyautocad: A Python library to control AutoCAD through COM, useful for connecting CAD logic to AI-generated instructions.
    • ChatGPT: Used manually for drafting assistance, generating macros, or validating code logic.
  3. Experimental Methods
    • Using GPT to generate AutoLISP scripts from natural language prompts.
    • Python scripts that:
      • Extract drawing data (e.g., block names, attributes, layer structures).
      • Send the data to GPT for suggestions or logic checks.
      • Return draft scripts or tag instructions for implementation.
    • Prompt chaining for common CAD workflows (e.g., automating drawing setup, annotation generation, or dimensioning logic).
Next Steps I’m Exploring
  • Building a lightweight GPT-based assistant that understands:
    • My project templates
    • CAD standards and layer naming conventions
    • Drawing metadata and workflows
  • Training or fine-tuning models on internal project data (to avoid relying on general-purpose responses).
