AutoCAD Forum
Instances or prefabs?
4 REPLIES 4
468 Views, 4 Replies
Hello everyone.
I'm sort of new to AutoCAD, with a background in game development.
One thing I'm missing in AutoCAD, which is commonplace in game engines, is the ability to create instances of objects or prefabs.
What specifically I'd like to do is to create groups and copies of said groups, and have changes made in one instance of the group automatically apply to the other.
Tags (2)
4 REPLIES 4
user181
Draw the item you want to duplicate and use the BLOCK command to create block of the items. Then copy that block wherever you need or want it. Then if you use the BEDIT command to modify the block all instances of the block will be updated.
gotphish001
You can also do the same as user181 says but use the command wblock. The block command saves the block in the drawing. If you use wblock it asks you were to save it. Then you can use it in other drawings too. I'd read about both types on the autodesk knowledge base to get the specifics of what they can do.
Blocks
Wblock
Nick DiPietro
Cad Manager/Monkey
in reply to: user181
Awesome!
Is there a way to create mirrored blocks?
Vinayv4v
There a lot of options available for blocks.
You can specify the angle for block to place or use the MIRROR command for the same block.
 Other types of blocks which includes parameters and actions are DYNAMIC BLOCKS. Which as you mentioned Mirrored Blocks (in which miirror is a parameter).
I have attached a simple example of how to create these.
For more details about Dynamic blocks refer this link and its sub links:
Cheers,
Vinay Vijayakumaran
Forma Design Contest
