use :
(findfile "fonts")
then hit Enter, that is where you put your .shx in
HI @hollandarc,
The folder containing your existing SHX font files is included in your Support File Search Path which you can look at in OPTIONS.
You can add your new SHX to that location or you can put it in your own custom folder and add that folder to the Support File Search Path as well. This can be handy to keep your personal and custom stuff out of the "factory" folders.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
If the font is one that you purchased, keep it in a folder with your other private stuff that is also added to the options support files instead of adding font files to the folder that Autodesk uses for the fonts that it supplies. You should also be aware that AutoCAD also scans the system fonts directory for supported fonts. As long as a folder is on the support files list, AutoCAD will find the fonts.
Hi @hollandarc,
It is always a good idea to keep your custom files separate from your application files in case anything gets corrupted or damaged. This can speed recovery.
Are you a local administrator on your workstation? I suggest this is a good thing as it can prevent permissions problems that frequently arise when using AutoCAD.
It is also a good idea to turn off UAC (User Account Control).
Are you on Windows 10 Per chance? Some users have reported problems installing fonts and other things without being in the God-mode (Super Admin permissions).
