02:13 AM
I downloaded the 4 parts of the installations files, extracted them to D:\Autocad setup files\
This went fine.
Tried to install the suite and each install failed giving the error above (Error: current directory path is too long. Setup quits).
So...I renamed the extracted folder and the old folder name turned up in the error message.
So...I deleted that extracted folder (restarted the machine) and extracted the files again and did not change the default (C:\Autodesk)
I tried to install and the error was the same as the first i.e. it listed the original extracted folder as being too long. (D:\Autocad setup files\.....)
Is there a .ini that gets saved where this path is saved???
Link copied
