Installation Unsuccessful
I am a Student in AutoCAD class and my teacher told us to download the free student trial. So thats what i did. So i create an account and yada yada yada start the download. It downloads fine up until it starts downloading 10 of 17 remaining. All of a sudden the installation stops and a screen pops up and says AutoCAD failed to download along with all of its counterparts (ReCap, App Manager, etc.). I have completely wiped my computer, and then updated it to current windows etc. The computer is brand new (bought in spring 2015) and its an Acer 64-bit. I have tried downloading this thing about 15 times. Here is the installation log file. Please help!
2015/10/20:22:03:12 Scott ACER === Setup started on ACER by Scott ===
2015/10/20:22:03:12 Scott ACER Path_Length: 155
2015/10/20:22:03:12 Scott ACER Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2015/10/20:22:03:12 Scott ACER Launch
2015/10/20:22:03:12 Scott ACER CommandLine /PK 001F1 /SN 900-63930085 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup....
2015/10/20:22:03:12 Scott ACER Current Directory C:\Users\Scott\AppData\Local\Temp\_AI3D53.tmp
2015/10/20:22:09:32 Scott ACER === Setup ended ===
2015/10/20:22:03:14 Scott ACER === Setup started on ACER by Scott ===
2015/10/20:22:03:14 Scott ACER Path_Length: 155
2015/10/20:22:03:14 Scott ACER Current Directory C:\Users\Scott\AppData\Local\Temp\_AI3D53.tmp
2015/10/20:22:03:14 Scott ACER Launch
2015/10/20:22:05:05 Scott ACER Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2015/10/20:22:09:30 Scott ACER Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2015/10/20:22:09:31 Scott ACER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Scott\AppData\Local\Temp\_AI3D53.tmp\Setup\AcSetup.dll
2015/10/20:22:09:31 Scott ACER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/10/20:22:09:32 Scott ACER PageOpen LaunchDialog
2015/10/20:22:10:05 Scott ACER PageOpen LicenseDialog
2015/10/20:22:10:05 Scott ACER PageOpen ProductInfoDialog
2015/10/20:22:10:05 Scott ACER PageOpen ProductSelectionDialog2
2015/10/20:22:10:22 Scott ACER PageOpen FullProgressDialog
2015/10/20:22:10:25 Scott ACER Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/10/20:22:10:36 Scott ACER Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/10/20:22:10:36 Scott ACER Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/10/20:22:10:59 Scott ACER Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/10/20:22:11:00 Scott ACER Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/10/20:22:11:16 Scott ACER Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/10/20:22:11:16 Scott ACER Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Scott\AppData\Local\Temp\vcredist_x86_2010.log
2015/10/20:22:11:30 Scott ACER Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2015/10/20:22:11:31 Scott ACER Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/10/20:22:11:47 Scott ACER Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/10/20:22:11:47 Scott ACER Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Scott\AppData\Local\Temp\vcredist_x64_2010.log
2015/10/20:22:11:58 Scott ACER Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2015/10/20:22:11:59 Scott ACER Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2015/10/20:22:12:34 Scott ACER Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2015/10/20:22:12:34 Scott ACER Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/10/20:22:12:58 Scott ACER Install DirectX Runtime Succeeded
2015/10/20:22:12:58 Scott ACER Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/20:22:13:33 Scott ACER Install FARO LS 5.1.0.30630 (64bit) Succeeded
2015/10/20:22:13:34 Scott ACER Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2015/10/20:22:15:44 Scott ACER Download Aborted CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2015/10/20:22:15:44 Scott ACER Install Autodesk Material Library 2014 Failed Download Failed, Installation aborted, Result=1603
2015/10/20:22:15:54 Scott ACER Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2015/10/20:22:15:55 Scott ACER Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/10/20:22:15:55 Scott ACER Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2015/10/20:22:15:55 Scott ACER Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2015/10/20:22:15:56 Scott ACER PageOpen InstallCompleteDialog
2015/10/20:22:37:38 Scott ACER === Setup ended ===
2015/10/21:17:07:32 Scott ACER === Setup started on ACER by Scott ===
2015/10/21:17:07:32 Scott ACER Path_Length: 155
2015/10/21:17:07:32 Scott ACER Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2015/10/21:17:07:32 Scott ACER Launch
2015/10/21:17:07:32 Scott ACER CommandLine /PK 001F1 /SN 900-63930085 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup....
2015/10/21:17:07:32 Scott ACER Current Directory C:\Users\Scott\AppData\Local\Temp\_AIB30E.tmp
2015/10/21:17:07:40 Scott ACER === Setup ended ===
2015/10/21:17:07:35 Scott ACER === Setup started on ACER by Scott ===
2015/10/21:17:07:35 Scott ACER Path_Length: 155
2015/10/21:17:07:35 Scott ACER Current Directory C:\Users\Scott\AppData\Local\Temp\_AIB30E.tmp
2015/10/21:17:07:35 Scott ACER Launch
2015/10/21:17:07:37 Scott ACER Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2015/10/21:17:07:38 Scott ACER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Scott\AppData\Local\Temp\_AIB30E.tmp\Setup\AcSetup.dll
2015/10/21:17:07:38 Scott ACER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/10/21:17:07:40 Scott ACER PageOpen LaunchDialog
2015/10/21:17:08:02 Scott ACER PageOpen LicenseDialog
2015/10/21:17:08:02 Scott ACER PageOpen ProductInfoDialog
2015/10/21:17:08:02 Scott ACER PageOpen ProductSelectionDialog2
2015/10/21:17:08:07 Scott ACER PageOpen FullProgressDialog
2015/10/21:17:08:08 Scott ACER Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2015/10/21:17:08:08 Scott ACER Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/10/21:17:08:32 Scott ACER Install DirectX Runtime Succeeded
2015/10/21:17:08:32 Scott ACER Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:17:08:44 Scott ACER Install FARO LS 5.1.0.30630 (64bit) Succeeded
2015/10/21:17:08:45 Scott ACER Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2015/10/21:17:09:26 Scott ACER Download Complete CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2015/10/21:17:09:26 Scott ACER Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:17:10:05 Scott ACER Install Autodesk Material Library 2014 Succeeded
2015/10/21:17:10:05 Scott ACER Download Play CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar....
2015/10/21:17:11:15 Scott ACER Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar....
2015/10/21:17:11:15 Scott ACER Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:17:11:40 Scott ACER Install Autodesk Material Library 2014 - Base Image Library Succeeded
2015/10/21:17:11:40 Scott ACER Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:17:11:54 Scott ACER Install Autodesk Content Service Succeeded
2015/10/21:17:11:55 Scott ACER Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:17:12:02 Scott ACER Install Autodesk Content Service Language Pack Succeeded
2015/10/21:17:12:02 Scott ACER Download Play ACAD http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.t...
2015/10/21:17:20:31 Scott ACER Download Aborted ACAD http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.t...
2015/10/21:17:20:31 Scott ACER Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2015/10/21:17:20:37 Scott ACER Rollback Autodesk Content Service Language Pack Succeeded
2015/10/21:17:20:50 Scott ACER Rollback Autodesk Content Service Succeeded
2015/10/21:17:21:20 Scott ACER Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2015/10/21:17:22:11 Scott ACER Rollback Autodesk Material Library 2014 Succeeded
2015/10/21:17:22:21 Scott ACER Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2015/10/21:17:22:21 Scott ACER Rollback DirectX Runtime Failed Failure is ignored, Result=1619
