Installation errors
Installation errors
Installation errors
It looks like I am getting a 1619 error. This was installed on my computer previously but I removed it to re-install it so i could change it from a network to a standalone licence and now I cant install it. I am also getting 1603 errors but I am installing as an administratior.
2015/8/10:16:30:30 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:30:30 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:30:30 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:30:30 lee.scorrar SCE0158 Launch
2015/8/10:16:30:30 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:30:30 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI29C4.tmp
2015/8/10:16:30:32 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:30:31 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:30:31 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:30:31 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI29C4.tmp
2015/8/10:16:30:31 lee.scorrar SCE0158 Launch
2015/8/10:16:30:31 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:30:34 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:30:36 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:30:36 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:31:17 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:31:17 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:31:23 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:31:24 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:31:24 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:31:24 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:31:24 lee.scorrar SCE0158 Launch
2015/8/10:16:31:24 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:31:24 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIFB45.tmp
2015/8/10:16:31:25 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:31:25 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:31:31 lee.scorrar SCE0158 PageOpen RepairDialog
2015/8/10:16:31:47 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:31:47 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:31:47 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" MUILANG="en-US" REINSTALL="ALL" REINSTALLMODE="eum" REMOVE=""  SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:32:58 lee.scorrar SCE0158 Reinstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:32:58 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:33:10 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:33:12 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:33:12 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:33:12 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:33:12 lee.scorrar SCE0158 Launch
2015/8/10:16:33:12 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:33:12 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIA1D0.tmp
2015/8/10:16:33:13 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:33:13 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:33:14 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:33:16 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:33:16 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:33:24 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:33:24 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:33:46 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:34:10 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:34:10 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:34:10 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:16:34:10 lee.scorrar SCE0158 Launch
2015/8/10:16:34:10 lee.scorrar SCE0158 CommandLine
2015/8/10:16:34:10 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8461.tmp
2015/8/10:16:34:13 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:34:11 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:34:11 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:34:11 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8461.tmp
2015/8/10:16:34:11 lee.scorrar SCE0158 Launch
2015/8/10:16:34:11 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8461.tmp\Setup\AcSetup.dll
2015/8/10:16:34:11 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:16:34:13 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:16:34:17 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:16:34:17 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:16:34:33 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:16:34:33 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:16:34:40 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:16:35:18 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:16:35:30 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:35:30 lee.scorrar SCE0158 Installing Exchange App Manager:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:35:38 lee.scorrar SCE0158 Install Exchange App Manager Succeeded
2015/8/10:16:35:38 lee.scorrar SCE0158 Installing Exchange Featured Apps plug-in:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:35:40 lee.scorrar SCE0158 Install Exchange Featured Apps plug-in Succeeded
2015/8/10:16:35:40 lee.scorrar SCE0158 Installing Autodesk® BIM 360™ Add-in for AutoCAD® 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:35:46 lee.scorrar SCE0158 Install Autodesk® BIM 360™ Add-in for AutoCAD® 2015 Succeeded
2015/8/10:16:35:46 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:16:35:52 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:37:27 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:37:27 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:37:27 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:37:27 lee.scorrar SCE0158 Launch
2015/8/10:16:37:27 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:37:27 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8616.tmp
2015/8/10:16:37:28 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:37:28 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:37:29 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:37:31 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:37:31 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:37:43 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:37:43 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:37:45 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:37:51 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:37:51 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:37:51 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:37:51 lee.scorrar SCE0158 Launch
2015/8/10:16:37:51 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:37:51 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIE362.tmp
2015/8/10:16:37:52 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:37:52 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:37:53 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:37:54 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:37:55 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:38:34 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:38:34 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:38:37 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:42:26 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:42:26 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:42:26 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:42:26 lee.scorrar SCE0158 Launch
2015/8/10:16:42:26 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:42:26 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI1673.tmp
2015/8/10:16:42:27 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:42:27 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:42:28 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:42:32 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:42:33 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:43:33 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:43:33 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:43:39 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:46:08 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:46:08 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:46:08 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:46:08 lee.scorrar SCE0158 Launch
2015/8/10:16:46:08 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:46:08 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIDB02.tmp
2015/8/10:16:46:10 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:46:09 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:46:09 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:46:09 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIDB02.tmp
2015/8/10:16:46:09 lee.scorrar SCE0158 Launch
2015/8/10:16:46:09 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:46:10 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:46:12 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:46:12 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:46:16 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:46:16 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:46:50 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:47:03 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:47:03 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:47:03 lee.scorrar SCE0158 Current Directory C:\Program Files\Autodesk\AutoCAD 2015\Setup\en-us\Setup
2015/8/10:16:47:03 lee.scorrar SCE0158 Launch
2015/8/10:16:47:03 lee.scorrar SCE0158 CommandLine /P {5783F2D7-E001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2015/8/10:16:47:03 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIB1B1.tmp
2015/8/10:16:47:04 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:47:04 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:47:04 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:47:04 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIB1B1.tmp
2015/8/10:16:47:04 lee.scorrar SCE0158 Launch
2015/8/10:16:47:04 lee.scorrar SCE0158 PageOpen MaintenanceDialog
2015/8/10:16:47:10 lee.scorrar SCE0158 PageOpen MaintVerifyReadyDialog
2015/8/10:16:47:12 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:47:12 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:47:16 lee.scorrar SCE0158 Uninstall Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:16:47:16 lee.scorrar SCE0158 PageOpen MaintFailedDialog
2015/8/10:16:47:39 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:49:55 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:49:55 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:49:55 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:16:49:55 lee.scorrar SCE0158 Launch
2015/8/10:16:49:55 lee.scorrar SCE0158 CommandLine
2015/8/10:16:49:55 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI5012.tmp
2015/8/10:16:49:58 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:49:56 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:49:56 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:49:56 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI5012.tmp
2015/8/10:16:49:56 lee.scorrar SCE0158 Launch
2015/8/10:16:49:56 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI5012.tmp\Setup\AcSetup.dll
2015/8/10:16:49:56 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:16:49:58 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:16:50:04 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:16:50:06 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:16:50:33 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:16:50:43 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:16:50:43 lee.scorrar SCE0158 Installing Exchange App Manager:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:50:43 lee.scorrar SCE0158 Install Exchange App Manager Succeeded
2015/8/10:16:50:43 lee.scorrar SCE0158 Installing Autodesk® 360:  TRANSFORMS="C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI5012.tmp\x64\Components\Cloudsync\AdSync-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:16:51:01 lee.scorrar SCE0158 Install Autodesk® 360 Succeeded Reboot is required
2015/8/10:16:51:01 lee.scorrar SCE0158 Installing Autodesk Application Manager: "C:\Temp\Autocad 2015\64Bit DVD\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2015/8/10:16:51:20 lee.scorrar SCE0158 Install Autodesk Application Manager Succeeded
2015/8/10:16:51:20 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:16:52:15 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:58:38 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:58:38 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:58:38 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:16:58:38 lee.scorrar SCE0158 Launch
2015/8/10:16:58:38 lee.scorrar SCE0158 CommandLine
2015/8/10:16:58:38 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIE3B9.tmp
2015/8/10:16:58:41 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:16:58:39 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:16:58:39 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:16:58:39 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIE3B9.tmp
2015/8/10:16:58:39 lee.scorrar SCE0158 Launch
2015/8/10:16:58:39 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIE3B9.tmp\Setup\AcSetup.dll
2015/8/10:16:58:39 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:16:58:41 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:16:58:45 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:16:58:45 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:16:59:08 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:16:59:08 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:16:59:12 lee.scorrar SCE0158 PageOpen BeginDeploymentDialog
2015/8/10:16:59:12 lee.scorrar SCE0158 CBeginDeploymentDialog::OnInitDialog reads PATH_LENGTH: 157
2015/8/10:16:59:16 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:16:59:45 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:16:59:48 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:00:18 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:00:51 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:00:52 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:00:53 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:00:59 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:05:45 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:05:45 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:05:45 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:05:45 lee.scorrar SCE0158 Launch
2015/8/10:17:05:45 lee.scorrar SCE0158 CommandLine
2015/8/10:17:05:45 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI673A.tmp
2015/8/10:17:05:47 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:05:45 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI673A.tmp\Setup\AcSetup.dll
2015/8/10:17:05:45 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:05:47 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:05:49 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:05:51 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:06:12 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:06:30 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:17:45 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:17:45 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:17:45 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:17:45 lee.scorrar SCE0158 Launch
2015/8/10:17:17:45 lee.scorrar SCE0158 CommandLine
2015/8/10:17:17:45 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI6576.tmp
2015/8/10:17:17:47 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:17:46 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI6576.tmp\Setup\AcSetup.dll
2015/8/10:17:17:46 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:17:47 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:17:55 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:17:58 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:18:26 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:18:45 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:17:18:45 lee.scorrar SCE0158 Installing Exchange App Manager:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:17:18:46 lee.scorrar SCE0158 Install Exchange App Manager Succeeded
2015/8/10:17:18:46 lee.scorrar SCE0158 Installing Exchange Featured Apps plug-in:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:17:18:47 lee.scorrar SCE0158 Install Exchange Featured Apps plug-in Succeeded
2015/8/10:17:18:47 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® Performance Reporting Tool:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:17:18:47 lee.scorrar SCE0158 Install Autodesk® AutoCAD® Performance Reporting Tool Succeeded Reboot is required
2015/8/10:17:18:48 lee.scorrar SCE0158 Installing Autodesk® BIM 360™ Add-in for AutoCAD® 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:17:18:49 lee.scorrar SCE0158 Install Autodesk® BIM 360™ Add-in for AutoCAD® 2015 Succeeded
2015/8/10:17:18:49 lee.scorrar SCE0158 Installing Autodesk Application Manager: "C:\Temp\Autocad 2015\64Bit DVD\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2015/8/10:17:19:45 lee.scorrar SCE0158 Install Autodesk Application Manager Succeeded
2015/8/10:17:19:51 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:17:20:02 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:25:18 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:25:18 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:25:18 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:25:18 lee.scorrar SCE0158 Launch
2015/8/10:17:25:18 lee.scorrar SCE0158 CommandLine
2015/8/10:17:25:18 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI4FF3.tmp
2015/8/10:17:25:20 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:25:19 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:25:19 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:25:19 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI4FF3.tmp
2015/8/10:17:25:19 lee.scorrar SCE0158 Launch
2015/8/10:17:25:19 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI4FF3.tmp\Setup\AcSetup.dll
2015/8/10:17:25:19 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:25:20 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:25:22 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:25:24 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:25:37 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:25:56 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:26:02 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:26:02 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:26:02 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:26:02 lee.scorrar SCE0158 Launch
2015/8/10:17:26:02 lee.scorrar SCE0158 CommandLine
2015/8/10:17:26:02 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIFAA3.tmp
2015/8/10:17:26:04 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:26:03 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIFAA3.tmp\Setup\AcSetup.dll
2015/8/10:17:26:03 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:26:04 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:26:05 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:26:07 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:26:28 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:26:33 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:28:52 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:28:52 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:28:52 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:28:52 lee.scorrar SCE0158 Launch
2015/8/10:17:28:52 lee.scorrar SCE0158 CommandLine
2015/8/10:17:28:52 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI952D.tmp
2015/8/10:17:28:54 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:28:53 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:28:53 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:28:53 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI952D.tmp
2015/8/10:17:28:53 lee.scorrar SCE0158 Launch
2015/8/10:17:28:53 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI952D.tmp\Setup\AcSetup.dll
2015/8/10:17:28:53 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:28:54 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:28:56 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:28:58 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:29:15 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:29:20 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:32:18 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:32:18 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:32:18 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:32:18 lee.scorrar SCE0158 Launch
2015/8/10:17:32:18 lee.scorrar SCE0158 CommandLine
2015/8/10:17:32:18 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIBDE1.tmp
2015/8/10:17:32:22 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:32:20 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:32:20 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:32:20 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIBDE1.tmp
2015/8/10:17:32:20 lee.scorrar SCE0158 Launch
2015/8/10:17:32:20 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIBDE1.tmp\Setup\AcSetup.dll
2015/8/10:17:32:20 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:32:22 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:32:24 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:32:28 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:32:44 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:32:48 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:36:50 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:36:50 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:36:50 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:36:50 lee.scorrar SCE0158 Launch
2015/8/10:17:36:50 lee.scorrar SCE0158 CommandLine
2015/8/10:17:36:50 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIE12A.tmp
2015/8/10:17:36:52 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:36:51 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIE12A.tmp\Setup\AcSetup.dll
2015/8/10:17:36:51 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:36:52 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:36:54 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:36:56 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:37:10 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:37:19 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:52:11 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:52:11 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:52:11 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:52:11 lee.scorrar SCE0158 Launch
2015/8/10:17:52:11 lee.scorrar SCE0158 CommandLine
2015/8/10:17:52:11 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIEEF0.tmp
2015/8/10:17:52:14 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:52:12 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:52:12 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:52:12 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIEEF0.tmp
2015/8/10:17:52:12 lee.scorrar SCE0158 Launch
2015/8/10:17:52:12 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIEEF0.tmp\Setup\AcSetup.dll
2015/8/10:17:52:12 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:52:14 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:52:17 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:52:19 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:52:32 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:55:58 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:57:08 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:57:08 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:57:08 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:17:57:08 lee.scorrar SCE0158 Launch
2015/8/10:17:57:08 lee.scorrar SCE0158 CommandLine
2015/8/10:17:57:08 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI78F6.tmp
2015/8/10:17:57:10 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:17:57:09 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:17:57:09 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:17:57:09 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI78F6.tmp
2015/8/10:17:57:09 lee.scorrar SCE0158 Launch
2015/8/10:17:57:09 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI78F6.tmp\Setup\AcSetup.dll
2015/8/10:17:57:09 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:17:57:10 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:17:57:20 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:17:57:22 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:17:57:39 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:17:59:46 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:17:59:46 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/8/10:18:00:07 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/8/10:18:00:07 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/8/10:18:00:26 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/8/10:18:00:26 lee.scorrar SCE0158 Installing DirectX Runtime: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\DirectX\DXSETUP.exe" /silent
2015/8/10:18:00:45 lee.scorrar SCE0158 Install DirectX Runtime Succeeded
2015/8/10:18:00:45 lee.scorrar SCE0158 Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:00:54 lee.scorrar SCE0158 Install Autodesk Material Library 2015 Succeeded
2015/8/10:18:00:54 lee.scorrar SCE0158 Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:01:01 lee.scorrar SCE0158 Install Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:01:01 lee.scorrar SCE0158 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:01:07 lee.scorrar SCE0158 Install Autodesk Content Service Succeeded
2015/8/10:18:01:07 lee.scorrar SCE0158 Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:01:08 lee.scorrar SCE0158 Install Autodesk Content Service Language Pack Succeeded
2015/8/10:18:01:09 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\acad\acad.mst;C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI78F6.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:01:43 lee.scorrar SCE0158 Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:18:01:44 lee.scorrar SCE0158 Rollback Autodesk Content Service Language Pack Succeeded
2015/8/10:18:01:45 lee.scorrar SCE0158 Rollback Autodesk Content Service Succeeded
2015/8/10:18:01:55 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:02:02 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 Succeeded
2015/8/10:18:02:02 lee.scorrar SCE0158 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/8/10:18:02:02 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:02:02 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:02:02 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:18:05:50 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:18:24:48 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:18:24:48 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:18:24:48 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:18:24:48 lee.scorrar SCE0158 Launch
2015/8/10:18:24:48 lee.scorrar SCE0158 CommandLine
2015/8/10:18:24:48 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIDC2B.tmp
2015/8/10:18:24:51 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:18:24:49 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:18:24:49 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:18:24:49 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIDC2B.tmp
2015/8/10:18:24:49 lee.scorrar SCE0158 Launch
2015/8/10:18:24:49 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIDC2B.tmp\Setup\AcSetup.dll
2015/8/10:18:24:49 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:18:24:51 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:18:24:54 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:18:24:56 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:18:25:21 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:18:26:00 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:18:26:00 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/8/10:18:26:05 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/8/10:18:26:05 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/8/10:18:26:12 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/8/10:18:26:12 lee.scorrar SCE0158 Installing DirectX Runtime: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\DirectX\DXSETUP.exe" /silent
2015/8/10:18:26:27 lee.scorrar SCE0158 Install DirectX Runtime Succeeded
2015/8/10:18:26:27 lee.scorrar SCE0158 Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:26:36 lee.scorrar SCE0158 Install Autodesk Material Library 2015 Succeeded
2015/8/10:18:26:36 lee.scorrar SCE0158 Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:26:43 lee.scorrar SCE0158 Install Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:26:43 lee.scorrar SCE0158 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:26:49 lee.scorrar SCE0158 Install Autodesk Content Service Succeeded
2015/8/10:18:26:49 lee.scorrar SCE0158 Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:26:50 lee.scorrar SCE0158 Install Autodesk Content Service Language Pack Succeeded
2015/8/10:18:26:50 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\acad\acad.mst;C:\Users\LEE~1.SCO\AppData\Local\Temp\_AIDC2B.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:27:25 lee.scorrar SCE0158 Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:18:27:26 lee.scorrar SCE0158 Rollback Autodesk Content Service Language Pack Succeeded
2015/8/10:18:27:27 lee.scorrar SCE0158 Rollback Autodesk Content Service Succeeded
2015/8/10:18:27:32 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:27:39 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 Succeeded
2015/8/10:18:27:39 lee.scorrar SCE0158 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/8/10:18:27:39 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:27:39 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:27:40 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:18:33:12 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:18:49:39 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:18:49:39 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:18:49:39 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:18:49:39 lee.scorrar SCE0158 Launch
2015/8/10:18:49:39 lee.scorrar SCE0158 CommandLine
2015/8/10:18:49:39 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8BDA.tmp
2015/8/10:18:49:43 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:18:49:41 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:18:49:41 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:18:49:41 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8BDA.tmp
2015/8/10:18:49:41 lee.scorrar SCE0158 Launch
2015/8/10:18:49:41 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8BDA.tmp\Setup\AcSetup.dll
2015/8/10:18:49:41 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:18:49:43 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:18:49:52 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:18:49:52 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:18:49:59 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:18:49:59 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:18:50:02 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:18:50:05 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:18:50:26 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:18:51:03 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:18:51:03 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/8/10:18:51:09 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/8/10:18:51:09 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/8/10:18:51:18 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/8/10:18:51:18 lee.scorrar SCE0158 Installing DirectX Runtime: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\DirectX\DXSETUP.exe" /silent
2015/8/10:18:51:34 lee.scorrar SCE0158 Install DirectX Runtime Succeeded
2015/8/10:18:51:34 lee.scorrar SCE0158 Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:51:44 lee.scorrar SCE0158 Install Autodesk Material Library 2015 Succeeded
2015/8/10:18:51:44 lee.scorrar SCE0158 Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:51:51 lee.scorrar SCE0158 Install Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:51:51 lee.scorrar SCE0158 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:51:57 lee.scorrar SCE0158 Install Autodesk Content Service Succeeded
2015/8/10:18:51:57 lee.scorrar SCE0158 Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:52:00 lee.scorrar SCE0158 Install Autodesk Content Service Language Pack Succeeded
2015/8/10:18:52:00 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\acad\acad.mst;C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI8BDA.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:52:38 lee.scorrar SCE0158 Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:18:52:39 lee.scorrar SCE0158 Rollback Autodesk Content Service Language Pack Succeeded
2015/8/10:18:52:40 lee.scorrar SCE0158 Rollback Autodesk Content Service Succeeded
2015/8/10:18:52:45 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:52:53 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 Succeeded
2015/8/10:18:52:53 lee.scorrar SCE0158 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/8/10:18:52:53 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:52:53 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:52:54 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:18:55:41 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:18:55:51 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:18:55:51 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:18:55:51 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:18:55:51 lee.scorrar SCE0158 Launch
2015/8/10:18:55:51 lee.scorrar SCE0158 CommandLine
2015/8/10:18:55:51 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI37B2.tmp
2015/8/10:18:55:53 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:18:55:52 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:18:55:52 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:18:55:52 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI37B2.tmp
2015/8/10:18:55:52 lee.scorrar SCE0158 Launch
2015/8/10:18:55:52 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI37B2.tmp\Setup\AcSetup.dll
2015/8/10:18:55:52 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:18:55:53 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:18:55:55 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:18:55:57 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:18:56:09 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:18:56:53 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:18:56:54 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/8/10:18:56:59 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/8/10:18:56:59 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/8/10:18:57:06 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/8/10:18:57:06 lee.scorrar SCE0158 Installing DirectX Runtime: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\DirectX\DXSETUP.exe" /silent
2015/8/10:18:57:22 lee.scorrar SCE0158 Install DirectX Runtime Succeeded
2015/8/10:18:57:22 lee.scorrar SCE0158 Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:57:31 lee.scorrar SCE0158 Install Autodesk Material Library 2015 Succeeded
2015/8/10:18:57:31 lee.scorrar SCE0158 Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:57:38 lee.scorrar SCE0158 Install Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:57:38 lee.scorrar SCE0158 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:57:44 lee.scorrar SCE0158 Install Autodesk Content Service Succeeded
2015/8/10:18:57:44 lee.scorrar SCE0158 Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:57:45 lee.scorrar SCE0158 Install Autodesk Content Service Language Pack Succeeded
2015/8/10:18:57:45 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\acad\acad.mst;C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI37B2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:18:58:01 lee.scorrar SCE0158 Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:18:58:02 lee.scorrar SCE0158 Rollback Autodesk Content Service Language Pack Succeeded
2015/8/10:18:58:03 lee.scorrar SCE0158 Rollback Autodesk Content Service Succeeded
2015/8/10:18:58:08 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:18:58:16 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 Succeeded
2015/8/10:18:58:16 lee.scorrar SCE0158 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/8/10:18:58:16 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:58:16 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:18:58:17 lee.scorrar SCE0158 PageOpen InstallCompleteDialog
2015/8/10:19:00:44 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:19:01:35 lee.scorrar SCE0158 === Setup started on SCE0158 by lee.scorrar ===
2015/8/10:19:01:35 lee.scorrar SCE0158 Path_Length: 157
2015/8/10:19:01:35 lee.scorrar SCE0158 Current Directory C:\Temp\Autocad 2015\64Bit DVD
2015/8/10:19:01:35 lee.scorrar SCE0158 Launch
2015/8/10:19:01:35 lee.scorrar SCE0158 CommandLine
2015/8/10:19:01:35 lee.scorrar SCE0158 Current Directory C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI76A5.tmp
2015/8/10:19:01:37 lee.scorrar SCE0158 === Setup ended ===
2015/8/10:19:01:36 lee.scorrar SCE0158 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI76A5.tmp\Setup\AcSetup.dll
2015/8/10:19:01:36 lee.scorrar SCE0158 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:19:01:37 lee.scorrar SCE0158 PageOpen LaunchDialog
2015/8/10:19:01:39 lee.scorrar SCE0158 PageOpen LicenseDialog
2015/8/10:19:01:41 lee.scorrar SCE0158 PageOpen ProductInfoDialog
2015/8/10:19:01:59 lee.scorrar SCE0158 PageOpen ProductSelectionDialog2
2015/8/10:19:03:04 lee.scorrar SCE0158 PageOpen FullProgressDialog
2015/8/10:19:03:04 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/8/10:19:03:09 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/8/10:19:03:09 lee.scorrar SCE0158 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\LEE~1.SCO\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/8/10:19:03:15 lee.scorrar SCE0158 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/8/10:19:03:15 lee.scorrar SCE0158 Installing DirectX Runtime: "C:\Temp\Autocad 2015\64Bit DVD\3rdParty\DirectX\DXSETUP.exe" /silent
2015/8/10:19:03:32 lee.scorrar SCE0158 Install DirectX Runtime Succeeded
2015/8/10:19:03:32 lee.scorrar SCE0158 Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:19:03:41 lee.scorrar SCE0158 Install Autodesk Material Library 2015 Succeeded
2015/8/10:19:03:41 lee.scorrar SCE0158 Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:19:03:48 lee.scorrar SCE0158 Install Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:19:03:48 lee.scorrar SCE0158 Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:19:03:54 lee.scorrar SCE0158 Install Autodesk Content Service Succeeded
2015/8/10:19:03:54 lee.scorrar SCE0158 Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:19:03:56 lee.scorrar SCE0158 Install Autodesk Content Service Language Pack Succeeded
2015/8/10:19:03:56 lee.scorrar SCE0158 Installing Autodesk® AutoCAD® 2015:  TRANSFORMS="C:\Temp\Autocad 2015\64Bit DVD\x64\en-us\acad\acad.mst;C:\Users\LEE~1.SCO\AppData\Local\Temp\_AI76A5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Temp\Autocad 2015\64Bit DVD\" INSTALLDIR="C:\AutoDesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/8/10:19:04:11 lee.scorrar SCE0158 Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2015/8/10:19:04:13 lee.scorrar SCE0158 Rollback Autodesk Content Service Language Pack Succeeded
2015/8/10:19:04:14 lee.scorrar SCE0158 Rollback Autodesk Content Service Succeeded
2015/8/10:19:04:19 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2015/8/10:19:04:27 lee.scorrar SCE0158 Rollback Autodesk Material Library 2015 Succeeded
2015/8/10:19:04:27 lee.scorrar SCE0158 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/8/10:19:04:27 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2015/8/10:19:04:27 lee.scorrar SCE0158 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
kasperwuyts
Try looking into this:
http://forums.autodesk.com/t5/installation-licensing/some-products-fail-to-install-result-1603/td-p/...
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
