Insertion points for text and Attributes differs
Message 1 of 10
Can anyone explain how to correct this issue
In the block the text and attribute have the same grip horizontal positions
However when the text adds to the attribute it aligns with the lower grip while the text is aligned with the upper grip, which magic parameter needs to be changed or what is the solution?
Replies (9)
Message 2 of 10
chriscowgill7373
Bottom Left, is what the left picture is justified to
Left is what the right picture appears to be justified to.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 10
I thought that but below are the properties of attribute and text
Message 4 of 10
chriscowgill7373
Is it trying to autostack the fraction?  can you post a drawing with an example?
Message 5 of 10
cadffm
Thats the Attributdefinition, not the Attribut (from the first picture),
please test it with a NEW Blockreference, or use ATTSYNC for that Block.
Sebastian
Message 6 of 10
Attached is the file with the title block and misaligned attributes against text elements
Message 7 of 10
chriscowgill7373
Its because they are multiline attributes.  If they are single line, it works just fine:
Message 8 of 10
cadffm
It's hard to describe
The ATTDEF Object is like a TEXT-Object, but if you create a multiline-attdef and you create a blockreference (with this multiline-attribute)
then Acad display it like a MTEXT.
A artifice of the Autodesk programmers to offer a Multiline-Attribute without having a "real" new Multiline-Attdef/Attribute Object.
And the position of insertionpoint Bottom-Left is different between TEXT and MTEXT (or better, the Text-Value position relative to the basepoint)
Sebastian
Message 9 of 10
Kent1Cooper
@cadffm wrote:
.... the position of insertionpoint Bottom-Left is different between TEXT and MTEXT (or better, the Text-Value position relative to the basepoint)
To elaborate on that, Bottom-Left [and also Bottom-Center and Bottom-Right] justification for plain Text goes to the bottom of possible  descenders below the base-line [the tails on lower-case g, j, p, q, y, slashes, parentheses, etc.] whether or not the Text contains any of those.  But for Mtext, it goes to the bottom of the actual character content  [which varies depending on whether there are any descenders, and which means it will shift  when you change the content between having and not having any descenders on the lowest line].  "Ordinary" Left/Center/Right justification for plain Text puts the baseline  at the level of the insertion point, and descenders [if there are any] go below  that level.  Mtext doesn't have  an equivalent to that kind of positioning.
Kent Cooper, AIA
Message 10 of 10
Now I understand the differentce between MTEXT and TEXT insertion points
As a note had to use https://forums.autodesk.com/t5/autocad-forum/can-t-convert-multiline-attributes-to-single-line/td-p/..., process to change the multiline attributes back to single line.
Thanks for help and support
