Inserting PDF into AutoCAD 2018
- Mute
- Permalink
- Report
I have a equipment file in PDF format that I would like to insert into my AutoCAD drawing. I am using AutoCAD 2018 and have gone to the "Insert" and selected "Import PDF". Located the file and selected it, PDF has 3 sheets, only want the 1st page. Have selected and picked "Specify insertion point on-screen", Scale = 1, Rotation=0, Use PDF layers=selected, Vector geometry, solid fills, truetype text all selected, Join line and arc segments, covert solid fills to hatches, apply lineweight properties all selected. When I say ok, I see a rectangle that I am able to place but when I do I get a message "No objects were imported". I understand that if PDF is not created with AutoCAD then you can't import it. I don't know what program was used to create this PDF. Any suggestions on what else to try?
Thank you,
Steve
