inserting 2nd new view from model space having custom ucs
coolkris
coolkris
Dear all,
I am having issue while inserting 2nd new view in layout from layout tab.
The first new view comes along as per custom ucs. The second new view aligns with wrold coordinates sytem.
For some reason I need to put detail of the layout, How this can be solved.
Krish
imadHabash
as much as i understand ... unlock your VP first then pick inside your VP then type PLAN then double enter .
Imad Habash
coolkris
Thanks for the reply. I want direct view from model using layout tab. insert new view similar to the view on left.
dbroad
Several  methods come to mind
  • mvsetup
    • Command sequence: mvsetup c c 1  <pick> <pick>
    • This command automatically switches to the current model ucs.
    • Command scripting (defun c:test ()(command "_.mvsetup" "_C" "_C" 1))
  • Saved View method
    • First save the current view in model space. Use the view command.  This allows you to crop the view and will save layer and scale configurations.
    • In model space, use vports. On the New Viewports tab, Change view to your named view. Choose Single. Click OK and pick the viewport corners.
  • Sheet set method
    • Save views as above. The view name becomes the title.
    • Save the view drawing.
    • Open the sheet drawing.
    • Drag the view on the sheet.
Architect, Registered NC, VA, SC, & GA.
coolkris
Thanks all the reply , options were excellent, but for the 1st new view on left. I just window crop from model the view and it was automatic and correct and "Super fast". Why only on 2nd new view this UCS setting back to world.
dbroad
Glad I could help.  Sorry, I don't understand the question: "Why only on 2nd new view this UCS setting back to world.?"
