Inserted drawing missing layers
Message 1 of 23
I am having trouble binding xrefs. I have tried Inserting the Xref into a new drawing but only a few layers are inserted. How do I fix this?
Accepted solutions (4)
Replies (22)
Message 2 of 23
RobDraw
That's not normal behavior and, without additional information, it's impossible to say how to fix it.
My guess is that the XREF file is somehow not compatible.
It would be helpful for you to share the problem child.
Rob
Message 3 of 23
cadffm
Even if the answer above is already marked as a solution [I guess it was a mistake, or?],
the following reason is more common and obvious:
You mean that not all objects appears, i guess: All Layers are there, but layers and objects are different things.
The option insert (instead of binding) was used and the layers in the target file are switched off or frozen.
@Anonymous
do you know the difference between both options in your bind process?
Sebastian
Message 4 of 23
RobDraw
Your answer is only obvious if the OP is not worded correctly and my response was marked as a solution by mistake and the OP also clicked the like button by mistake. I was surprised myself but they did click both without providing any more information.
Rob
Message 5 of 23
Sorry for the confusion.
I have a file which include two xrefs. Til now all three files have been placed in the same folder which allowed the xrefs to be visible, within the main drawing. Our company is in the process of transferring and linking all 2D drawings to a BIM program. So I am binding all xrefs which usually are architect floor plans, which have been used to draw on the technical installations (HVAC, electrical, etc).
The usual issue I've had was that, when I right click on the Xref and click bind, the entire drawing that was in the Xref disappeared.
I believe this is due to proxy objects and to fix this I have used the method recommended here. That is to open a new drawing, insert the problem xref, explode it, save and then link the xref path to this newly made drawing, and then bind.
This usually works,  however in this instance when I tried to insert the problem xref into a new drawing, part of the drawing disappeared. So my question is, why is this problem xref not showing the entire drawing when inserted to a new drawing? and is there a way to fix this? I have thawed, unlocked all layers before inserting and this didn't help. I am able to open the problem xref and view the drawing and it shows the entire drawing.
Message 6 of 23
cadffm
- So my question is, why is this problem xref not showing the entire drawing when inserted to a new drawing?
Impossible to know without the files for checking it.
XRef-DWG, Main-DWG and your Main-DWG after your "Bind" process (saveas with another name like Main-result.dwg)
- and is there a way to fix this?
First we need to know what the problem is, then we can answer this question.
-I have thawed, unlocked all layers before inserting and this didn't help.
Nothing to do with the bind process.
- I am able to open the problem xref and view the drawing and it shows the entire drawing.
We are not able to open and checking the XRef-Dwg, change this, share your files and we will see.
But again: I am right that all layers imported, you just missing some objects, right?
Sebastian
Message 7 of 23
RobDraw
What program will you be using the files in?
If the problem is the proxy objects and it probably is, then you need to convert them. Your method has a couple of flaws as you have found. Have the people generating the drawings EXPORT them for you. If that is too much trouble and the drawings were made with an AutoCAD vertical, you can do it yourself by downloading Drawing TrueView (free from Autodesk) and convert the drawings.
Rob
Message 8 of 23
Thank you for your answer. I need to check with my boss if these files can be shared. I will post here if I can. Thanks again.
Message 9 of 23
RobDraw
In the mean time, you can try my suggestion. If you have any trouble with using Drawing TrueView to get the desired output, just ask.
Rob
Message 10 of 23
Thank you! I am not familiar with Drawing TrueView but I've just downloaded it. Can you outline the steps I need to take please?
Also I'm not sure if the drawings were made with AutoCAD vertical. How do I check this?
The drawings were made in 2008 and they are drawings showing the sanitary pipework. Actually its the pipelines that disappear.
Message 11 of 23
RobDraw
Sorry, I don't have time to write a complete tutorial on how to use it. It is a very simple program with few options. Take some time to explore it, do some internet searches, on it and familiarize yourself with it. I'll be happy to help you with any aspects that you have trouble with.
Rob
Message 12 of 23
No, I meant with regards to converting this drawing in Trueview. Do I select DWG convert and then which conversion setup do I use?
Message 13 of 23
RobDraw
Does this help?
You need to choose an option with "Exploded AEC Objects".
Rob
Message 14 of 23
It didn't work. I still get the notice " Some objects in the specified Xref(s) failed to bind when I tried binding the xref.
I  also tried binding the xref within Trueview by clicking on the Bind External references option within the Modify Conversion Setup window.
Message 15 of 23
cadffm
Share your files.. you asked, what was the answer?
Best way: Command ETRANSMIT
Standard setting
Share the ZIP file with all needed stuff.
Without sharing:
Are you able to bind this xref in a bew empty file?
Are the Proxy objects in that file?
Set proxynotice to 1 and open the xref file, appears a message about Proxys?
Sebastian
Message 16 of 23
I haven't yet received an answer about sharing these files.
I tried inserting the drawing with the xrefs into a new drawing, reloaded the xref and still the error " Some objects in the specified Xref(s) failed to bind."
I chose the options " Show Proxy Graphics" and " Do not show proxy graphics". Both times the same error message as above.
Proxynotice was set to 1.
The following shows the Proxy info when I opened the problem Xref. If this is unreadable I have attached this as an attachment as well. Could it be because I don't have additional applications installed such as MagiCAD, etc? It is the piping that disappear when I try to bind.
Message 17 of 23
cadffm
YES.
without the file i am sure for 99%
AutoCAD does not know these objects and does not know how to deal with these objects when binding,
Sebastian
Message 18 of 23
Yes, you are correct. All layers are in the drawing just the objects (piping) is missing from the drawing.
Also how do I share these files here?
Message 19 of 23
cadffm
Sebastian
Message 20 of 23
I've now attached the problem drawings here.
