Insert, Xref and US Survey Feet
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi folks,
I have a survey file from our surveyor, drawn in US Survey Feet. INSUINTS is correctly set to 21 in that file.
In our file, drawn in INCHES, INSUNITS set to 1, I'm seeing different results between inserting and xrefing the survey in.
If I INSERT the survey, the unit conversion is listed correctly as US Survey Feet and the scale is 12.0000
If I XREF the survey in, the unit conversion is also listed correctly as US Survey Feet and the scale is also 12.0000, however, the plan is scaled up ever so slightly so that at the distance from 0,0 that the plan is, they are off by about 2'-7". NOTE: This is a scaling issue, not an alignment issue.
This happens in AutoCAD 2018 and in 2022.
Anyone else seeing this behavior?
