Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Insert Object dialog does not show other option in AutoCAD
maniesh1175
maniesh1175
Insert object dialog box does not show other option in AutoCAD , I am attaching the image for reference.
Replies (12)
cadffm
And what are you missing, what are you trying?
Sebastian
J-Porter
You can attach an image using the IMAGE command.  What type of image are you attempting to import?
maniesh1175
I cannot find the Microsoft Excel options for inserting the spreadsheet
maniesh1175
cadffm
As OLE = Copy&Paste, often the worst choice.
As AutoCAD objects = select excel cells and copy to clipboard (CTRL+C), start pastespec in AutoCAD -> select AutoCAD Objects
As TABLE which linking to the Excel spreadsheet , start the TABLE command!
Sebastian
J-Porter
You can copy and paste special or your can create a data link to the Excel spreadsheet.
They both have their own set of pros and cons.
paullimapa
strange because I have so many more options on my Insert Object Type list:
Paul Li
IT Specialist
@The Office
J-Porter
I believe that box is populated with the software that you have installed and that can be inserted into your drawing.
maniesh1175
I have tried to reset AutoCAD to default and issue still persist.
J-Porter
Have you tried the Copy and Paste Special option or the Data Link option?  Those are the most recommended ways to import portions of an Excel spreadsheet.
maniesh1175
datalink command works fine
maniesh1175
datalink command works and I can insert excel using this option. I am curious why I cannot get other option in Insert object command
