Insert object dialog box does not show other option in AutoCAD , I am attaching the image for reference.
As OLE = Copy&Paste, often the worst choice.
As AutoCAD objects = select excel cells and copy to clipboard (CTRL+C), start pastespec in AutoCAD -> select AutoCAD Objects
As TABLE which linking to the Excel spreadsheet , start the TABLE command!
Sebastian
You can copy and paste special or your can create a data link to the Excel spreadsheet.
They both have their own set of pros and cons.
strange because I have so many more options on my Insert Object Type list:
Have you tried the Copy and Paste Special option or the Data Link option? Those are the most recommended ways to import portions of an Excel spreadsheet.
datalink command works and I can insert excel using this option. I am curious why I cannot get other option in Insert object command
