Insert Excel .xlsm with Headers
1wildwes
1wildwes
I need to insert an Excel .xlsm file as shown in the attachment with the Headers showing over each column.. The spreadsheet currently is an OLE object, Embedded, and has Headers over each segment or spreadsheet view. I'll need 4 to 6 total columns on 2 to 3 sheets with the same header over each column as in the spreadsheet the rows are under the same Header columns. I am able to get the spreadsheet in using Edit/Paste but can only get the header over the 1st insertion. I am also to change the scale but am not able to match the text size to get 2 columns on each 24 x 36 sheet. Also, if possible I would like the link to be dynamic. I've also tried Datalink and Table commands.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.565 Vistas
4 Respuestas
Respuestas (4)
leeminardi
Solución aceptada
Try the following and see if it helps.
  1. In Excel use freeze panes to fix the header at the top no matter how far down you scroll.
  2. Select the range of cells for your page 1 and copy to clipboard.
  3. In AutoCAD right-click and do Paste Special and select Paste Link to enable the pasted table to be updated when changes are saved in Excel.
  4. To select a range that starts in a row not near the top, select and hide (right-click to see the hide option) the rows above it you do not want (except for the header rows) before selecting the cells you want.  YOu should now be able to select the header rows and rows further down the spreadsheet with getting the intermediate rows.
lee.minardi
1wildwes
This works great with the exception that when I hide the rows in Excel from a previous insertion set the rows also disappear in the dwg. I had to insert them with Paste instead of Paste Link. Do you know a way to avoid that? Thank you very much either way!
0 Me gusta
TrevN
Investigate using Tables with a Data link.
Much more powerful and useful.
0 Me gusta
1wildwes
I've tried and I'm trying again using Table. However it's asking me to save to only .xls which is not optimal with the macros in the Excel file. Every time I use the Table command nothing happens for at least 15 minutes. I'm going to let it run for a longer time period to see the result. However, the only .xls option is most likely a deal breaker.
0 Me gusta
