Insert command not working
Message 1 of 10
I can create a new block and save it to our server. I usually type insert to add it to a drawing. For some reason, when I type insert, nothing happens. I have tried using the insert tab to locate the block under libraries but still nothing. I have to open the block file and copy and paste it in. Any ideas on how to fix this?
Replies (9)
Message 2 of 10
Kent1Cooper
Does it show anything at the Command line?  A prompt?  A message of some kind?  If you're expecting a dialog box, and it doesn't bring that up but has a prompt at the Command line, check you FILEDIA System Variable setting.
Kent Cooper, AIA
Message 3 of 10
No, there is nothing on the command line. I type the command and nothing happens.
Message 4 of 10
FILEDIA is currently set at 1. What are the options? I don't know anything about this.
Message 5 of 10
imadHabash
would you please check if there is any palette called BLOCKS on your CAD screen . maybe it's Auto hide .
Imad Habash
Message 6 of 10
Kent1Cooper
HELP will tell you all about it.
Kent Cooper, AIA
Message 7 of 10
I do not see that anywhere.
Message 8 of 10
I use toolbars and noticed in the upgrade to 2020, the interface for inserting blocks changed.  I did not care for the change so now I type "classicinsert" into the command line to use the old interface.  This may be an option if all else fails.
Message 9 of 10
Yes, that worked! Thanks!
Message 10 of 10
ianA8KHF
Community Visitor
Community Visitor
I was experiencing this problem and CLASSICINSERT also worked - also prompted me that the original dwg title was too long and prompted me to re-assign the title within the drawing. I just renamed it to something shorter and solved the problem. Posting just in case it helps someone else!
