Inject Layer Properties Into Its Objects As Overrides
koolestani
koolestani
Hi
I want to move some objects into layer 0 and for the objects to retain their properties from their original layers. I understand for that to happen these properties must be overridden and not "by layer"; since overridden properties are retained even when the object is moved to another layer.
I have a situation where I have a layer containing both, objects with their properties set to "by layer" and others that have overridden properties. And there are many such layers. Is there a LISP solution that can make it so that the properties (lineweight, linetype & color) defined for the layer these objects are in, be applied to them all as overrides?
Thanks for the response 🙂.
pendean
Community Legend
Community Legend
"some objects" means what please?
BLOCKs do what you want, not much else: content inside the block are on layer 0 and set to BYBLOCK or BYLAYER for all the properties settings.
There are many "fix my blocks" lisp routines around, explore with a quick HELP.
Post back if you get stuck.
HTH
Kent1Cooper
I made a routine to do that with the elements in Block definitions, that should be easily modifiable to apply to selected top-level objects.
Try BENL0CL.lsp, available >here< [= Block Entities including in Nested Blocks within, to Layer 0 with Color & Linetype taken from entity's original layer].
If you want Color, Linetype and Lineweight, try >this< variant that adds that.
Kent Cooper, AIA
koolestani
Thanks for the replies and I'm sorry it took me so long to reply.
@pendeanyour method is kind of a false way of achieving the results I was hoping for.
@Kent1Cooperthis routine seems to be exactly what I was looking for! Thank you very much. I'll let you know if I find some quirks or need your help to get some bits tweaked. I saw BENL0, BENL0CL, and BENL0CLW, and went with BENL0CLW according to my requirements.
