INFORMATION SUBTRACT COMMAND
tecnico423NCJ
tecnico423NCJ
Autocad automatically erases solids (of the second selection) when you use SUBTRACT command.
I just want to be sure that this command works only in this way.
Is not possible to retain solids (of the second selection) after using SUBTRACT command, do you confirm this?
paullimapa
Confirmed because that’s how the Subtract command works
https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-14872FC1-8827-4D3B-978E-20936F9A78E...
Paul Li
IT Specialist
@The Office
Valentin_CAD
@tecnico423NCJ ,
Knowing this, you should COPY the model or file before performing the command.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
AVCPlugins
I agree with you that it's very inconvenient when you can't store the subtractable solid to subtract from other solids. I didn't find a ready solution. The DelObj system variable does not work with the subtract command. I had to solve this problem with plugins. In addition, I had to subtract with a gap. This is definitely not possible with regular means.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
tecnico423NCJ
Exactly,
in this case other softwares work smarter. Thank you
zulqarnainjabbar99
Community Visitor
Community Visitor
Exactly,
